E-body 8.75 case, which is correct 489, 742 or 741???
#552150
12/12/09 05:56 PM
12/12/09 05:56 PM
Posts: 110 Aurora
ebodiesonly
Aurora
What would be the correct 8.75 case for a 1970 Challenger, 489, 742 or 741?
1# Challenger 383-4, SPD early January 1970, gears 3.23+SG 2# Challenger 383-2, SPD late October 1969, gears 2.76, no SG
Both are original 383 cars, and have broadcast sheet, but it doesn't tell anything about the center section what was used?
1970 Challenger R/T 383 1970 Challenger Convertible 383
Re: E-body 8.75 case, which is correct 489, 742 or 741???
[Re: ebodiesonly]
#552155
12/12/09 10:22 PM
12/12/09 10:22 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Actually, it does, kind of.
Look on line 4 of your broadcast sheets. Note the numbers in the boxes marked 'Axle' then compare those numbers to the B.C. part number on the chart at this link;
http://www.hamtramck-historical.com/images/TSBs/1970/D70-3-2%20page4.jpg
[Re: Snoopy]
#552160
12/12/09 10:44 PM
12/12/09 10:44 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I just found a broadcast sheet for a 70 383 Cuda with a 741 carrier. SPD 423.
Mine has a SPD of A19 but the assembly date of the engine is 10-29, the 3rd member assy date is 10-28 & the axle assy date is 10-29... Obviously it didn't meet the SPD...
[Re: noschevys]
#552164
12/13/09 12:10 PM
12/13/09 12:10 PM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
My 71 challenger with 383-4 has 017 on the broadcast sheet, but I don't se it listed. It has 489 on the case and 3.23 gears.
1971 rear axles were covered here: '71 cars w/discs & 11" rear drums
