Old Crane Hemi cam grinds... #551968
12/12/09 04:18 PM
12/12/09 04:18 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Anyone have any info on the following Crane Cams Mech roller Hemi camshafts.
R 285/410-8
R 290/446-4
R 286/500-4
R 325
Im almost 100% sure the last set of numbers is lobe lift.
There was a post on here several months ago that might have mentioned one of these cams.
I would like to pick one that would best fit my application...
572 Hemi, heads flow 460cfm.700 lift, 13.8:1 compression, MP X-Ram.
Re: Old Crane Hemi cam grinds... [Re: Bob_Coomer] #551969
12/12/09 04:29 PM
12/12/09 04:29 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
yes duration then lobe lift. The second one looks good for you. I may know someone that may have one, I'll try to find out.
Re: Old Crane Hemi cam grinds... [Re: Bob_Coomer] #551970
12/12/09 04:32 PM
12/12/09 04:32 PM
Rock Springs
Rock Springs
Found this old DCX Cam chart..Looks like this is the specs for the 290 cam...I know some of the old Racer Brown cams were very close r shared the same specs alo.
6 Cyl. P4120243 D.C. 244-108 244 .436" 102 .010 .020
6 Cyl. P3690766 SS14-112 268 .450" 108 .016 .020
6 Cyl. P3690768 ST21-110 286 .520" 108 .016 .020
A Eng. P3412044 68 340 Man.-114 276/284 .444/.453" 112 Zero
A Eng. P3690213 Street Hemi GT-112 284 .471/.474" 109 Zero
A Eng. P3690769 SSH-44-108 292 .510" 110 Zero
A Eng. P4007619 SSH-25/44 286/292 .485/.510" 108 Zero
A Eng. P4007275 C. D. Stock "Cheater" 336/348 .462/.473 108 Zero
A Eng. P4120231 D.C. 284-108 284 .484" 108 Zero
A Eng. P4120231 D.C. 292-108 292 .509" 108 Zero
A Eng. P3412016 ST21-108 286 .520" 110 .018 .022
A Eng. P2836146 STX21-105 306 .560" 105 .028 .032
A Eng. P4120653 D.C. 284-112 284 .542" 110 .028 .032
A Eng. P4120655 D.C. 296-110 296 .572" 108 .028 .032
A Eng. P4120657 D.C. 312-106 312 .606" 104 .028 .032
A Eng. P4120148 D.C. 320-102 320 .630" 100 .024 .028
A Eng. P3690795 R280-427-1 10 Crane *280 .640" 108
A Eng. P3690589 Magna. Velocity-110 324 .633" 110 .024 .028
A Eng. P4007278 R-278-284-.413-.427-06 *278/284 .620/.640" 106 .035 .035
Cam Dyn.
A Eng. P4007509 R-284,427-05 Cam Dyn. *284 *284 108 .035 .035
A Eng. P3690796 R-296-4778-1 10 Crane *296 .717" 109 .024 .028
B Eng. P3690214 Street Hemi Gr.-108 284 .471/.474" 106 Zero
B Eng. P3412073 SSH-25-108.5 286 .485" 108 Zero
B Eng. P3690812 SSH-44-108 292 .510" 106 Zero
B Eng. P4007277 C.D. Stock "Cheater" 352/380 .467/.483 108 Zero
B Eng. P4120235 D.C. 284-108 284 .484" 108 Zero
B Eng. P4120237 D.C. 292-108 292 .509" 108 Zero
B Eng. P3690816 Stage 11-115 300/308 .518" 110 .028 .032
B Eng. P4120659 D.C. 284-112 284 .528" 110 .028 .032
B Eng. P4120661 D.C. 296-110 296 .557" 108 .028 .032
B Eng. P4120663 D.C. 312-106 312 .590" 104 .028 .032
B Eng. P3690159 STX-22 310 .590" 108 .028 .032
B Eng. P3690588 Mini Express-107 316 .654" 107 .024 .028
B Eng. P4120042 R280-.4468-08 Crane *280 .670" 108 .035 .035
B Eng. P4007279 R286-500-108 Cam Dyn. *286 .750" 107 .035 .035
Hemi P3690814 SSH-44-108 292 .510" 106 Zero
Hemi P4007945 C.D. Stock "Cheater" 342/348 .490/.480" 103 Zero
Hemi P3412090 STX22-105 310 .590" 104 .028 .032
Hemi P3571029 725-105 340 .643/.623" 103 .028 .032
Hemi P3690587 Mini Express-104 324 .684/.663" 103 .024 .028
Hemi P3690591 R-290-446-104- Crane *290 .700/.678" 103 .028 .032
Hemi P4007253 R292-500-106 Cam Dyn. 0292 .785/.760" 103 .032 .032
Hemi P3690839 R-296-4778-108 Crane *296 .750/.726" 108 .032 .032
Post deleted by Defbob [Re: Bob_Coomer] #551971
12/12/09 04:37 PM
12/12/09 04:37 PM
Re: Old Crane Hemi cam grinds... [Re: Bob_Coomer] #551972
12/12/09 04:46 PM
12/12/09 04:46 PM
Rock Springs
Rock Springs
Found the specs for the following cam also.
R286/500-4
286/292 dur at .050
Lift .785/.760
Opens Closes ADV Duration
Intake 51.0 BTDC 95.0 ABDC 326.0 °
Exhaust 102.0 BBDC 50.0 ATDC 332.0 °
Looks like this one has a pretty wide LSA...like 113.5-114....
Re: Old Crane Hemi cam grinds... #551973
12/12/09 04:47 PM
12/12/09 04:47 PM
Rock Springs
Rock Springs
#3 very close to my Duster
Does yours have a wide LSA like this one Fred?
Re: Old Crane Hemi cam grinds... [Re: Bob_Coomer] #551974
12/12/09 04:51 PM
12/12/09 04:51 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
isn't that normal for a Hemi grind? to reduce the intake charge loss out the exhaust?
Re: Old Crane Hemi cam grinds... [Re: TS3303] #551975
12/12/09 04:55 PM
12/12/09 04:55 PM
Rock Springs
Rock Springs
You got me Jim...I havent the foggest idea on these engines...
Re: Old Crane Hemi cam grinds... [Re: Bob_Coomer] #551976
12/12/09 04:59 PM
12/12/09 04:59 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
me either, not a Hemi guy. maybe Jeff will post and add some info to Hemi grinds.
Post deleted by Defbob [Re: Bob_Coomer] #551977
12/12/09 05:54 PM
12/12/09 05:54 PM
Re: Old Crane Hemi cam grinds... #551978
12/13/09 03:12 AM
12/13/09 03:12 AM
Manitoba, Canada
liteweight Offline
liteweight  Offline
Manitoba, Canada
I have a brand new Hemi R290 cam in the box with a complete set of new lifters. I also a new set of matching valve springs for this cam. Pm me if your interested.
Liteweight
Re: Old Crane Hemi cam grinds... [Re: TS3303] #551979
12/13/09 09:51 AM
12/13/09 09:51 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
When we were running hemi's back in the day, we shrunk the exhaust valve to 1.85", and were going to go with smaller exhaust lobes.
Re: Old Crane Hemi cam grinds... [Re: Bob_Coomer] #551980
12/13/09 04:03 PM
12/13/09 04:03 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I replied to your PM.
Floyd Lippencott IV
Re: Old Crane Hemi cam grinds... [Re: Bob_Coomer] #551981
12/13/09 10:08 PM
12/13/09 10:08 PM
SLC, Utah
mgpanos Offline
mgpanos  Offline
SLC, Utah
The R286/500-4 was commonly used in the Super Stock Hemis in the late 70's and maybe early 80's. The R290/446-4 was the first popular Crane grind for the Pro Stock-style Hemis, but was a killer on valve springs. It was replaced by the R296/4778-8 which wasn't quite so hard on springs even with more lift. I have never heard of the R285/410-8 but suspect it was for the heavier Super Stock cars.
Mark
Re: Old Crane Hemi cam grinds... [Re: Bob_Coomer] #551982
12/14/09 11:10 AM
12/14/09 11:10 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
I run a Comp Cams 296 Duration, 790 lift, 108 LSA. Seems to have good torque.
Re: Old Crane Hemi cam grinds... [Re: RAT PATROL] #551983
12/15/09 01:29 PM
12/15/09 01:29 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
The Crane R290-446-04 is the oldest cam, an early SS Cam, 290 @.050 int and exh, .446 lobes int and exh, LSA 104, 82 overlap, gross Int lift .700, Exh .678. This was generally replaced by the R292-500-06, .500 lobes, LSA 106, 80 overlap, gross lift .785/.760. The SS/DA cam was the R286-500-04,.500 lobes, LSA 104, 78 overlap, gross lift .785/.760. The R296-4778-08 was known as a 4 speed SS/A cam, .478 lobes, LSA 108, 80 overlap, gross lift .750/726.
Be a Rebel- Break the Laws of Physics!
Post deleted by Defbob [Re: mbogina] #551984
12/15/09 01:35 PM
12/15/09 01:35 PM
Re: Old Crane Hemi cam grinds... #551985
12/15/09 07:40 PM
12/15/09 07:40 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Dont know if this will work.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Old Crane Hemi cam grinds... [Re: deaks] #551986
12/15/09 08:11 PM
12/15/09 08:11 PM
Rock Springs
Rock Springs
Thank you deaks...thanks a bunch
Re: Old Crane Hemi cam grinds... [Re: deaks] #551987
12/15/09 11:29 PM
12/15/09 11:29 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
Were did you find the info for hemi grind cams...i've been looking with no luck..
here's my cam info R296/435-10X 66-2096 any help would be appreciated...not trying to hi-jack this thread.
