Trans slippage problems & would a OBDll Scanner tell me #551693
12/12/09 01:57 PM
12/12/09 01:57 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I have a 02 Dodge Ram 4x4 1500 360V8 quad cab with the auto 46RE trans and the trans is slipping.
I have not seen any check engine lignts pop up at all and I am wondering if a OBDII scanner would tell me anything at all about the problem with the truck if no warning lights are on?
Re: Trans slippage problems & would a OBDll Scanner tell me [Re: Blakcharger440] #551694
12/12/09 02:09 PM
12/12/09 02:09 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
usually you will get a check engine like and a code for a speed sensor...
dont think you will get anything if the clutches or bands are bad...
is it slipping in every gear or ?
have you ever changed the filter/ fluid and adjust the bands?
Tony
70 AARCuda Vitamin C
Re: Trans slippage problems & would a OBDll Scanner tell me [Re: 70AARcuda] #551695
12/12/09 02:22 PM
12/12/09 02:22 PM
Wichita,KS
Wichita,KS
Yes I changed he fluid and filter about 3weeks ago....and then started to have problems. I havent ever adjusted the bands.
It seems to slip in every gear. When the trans is cold I can put it in any gear but when the trans starts to heat up it doesnt want to move when I select a gear but may or may not if you wait awhile and it might shift itself into gear and then soon start slipping again.
It seems to be making a tinney humming noise when I put it is reverse or any forward gear but the noise stops when put in park.
How do I adjust the bands?
Re: Trans slippage problems & would a OBDll Scanner tell me [Re: Blakcharger440] #551696
12/12/09 02:30 PM
12/12/09 02:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it started after you did the filter change I'd drop the pan and see what you did wrong. Did you use atf+4 fluid? How many quarts did you put back in?
Re: Trans slippage problems & would a OBDll Scanner tell me [Re: Blakcharger440] #551697
12/12/09 02:31 PM
12/12/09 02:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
It seems to be making a tinney humming noise when I put it is reverse or any forward gears
Had the same noise and slipping issuses with my 1500 Ram PU,.....for about 2 days, the converter was breaking up and pumping crap thru the tranny, lost all "gears" the next day,.....get ready for the rebuild, or replacement
Re: Trans slippage problems & would a OBDll Scanner tell me [Re: stumpy] #551698
12/12/09 02:42 PM
12/12/09 02:42 PM
Wichita,KS
Wichita,KS
I put in six quarts of ATF 4 total after just dropping the pan.
I will check again to see if there is anything as all I did was just change the filter.
