Synthetic Dot 3
#551683
12/12/09 12:45 PM
12/12/09 12:45 PM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
Has anyone used this before and is it compatible with standard brake fluid? ![](/ubbthreads/images/graemlins/shruggy.gif) My wifes van has a leaky wheel cylinder and she bought a 1 quart bottle of Prestone Synthetic Dot 3 brake fluid. Now before everyone starts telling me I need to replace the offending wheel cylinder, just let me say...DUH! I will be a full brake job on it tomorrow. I'm just wondering how compatible the synthetic Dot 3 will be with standard Dot 3. I've never heard of synthetic Dot 3 before. I thought all synthetic brake fluid was Dot 5, which can be used, but you have to flush the whole system of the Dot 3 first. This bottle says can be used in all Dot 3 systems. So what do you think? Will I be ok? Or should I take it back and get a bottle of regular brake fluid?
Re: Synthetic Dot 3
[Re: dodgeram440]
#551685
12/12/09 01:53 PM
12/12/09 01:53 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
You'll be fine using it. Synthetic and silicone are 2 different animals. Perosnally,I use the Valvoline synthetic(SynPower) as it has a higher boiling point than DOT 3 and 4 fluids.
