Drum brakes...8 3/4 vs. 7 1/4?? #551315
12/11/09 07:13 PM
12/11/09 07:13 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Question before I start tearing into my latest project : First, let me say I know the backing plates between a 7 1/4 and 8 3/4 are different. But...
I have all new brakes on a car that has a 7 1/4 rear, but will swapping for an 8 3/4. Just curious if all those new brake parts can be used on the 8 3/4 with the correct backing plates.
One would assume that other than the backing plates, 10x2.5 drums brake assemblies had all the same parts...
Re: Drum brakes...8 3/4 vs. 7 1/4?? [Re: cudadoug] #551316
12/11/09 08:14 PM
12/11/09 08:14 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
If you have the aftermarket axles then yes the brakes from a 7 1/4 rear from an 80's fifth avenue will work. Done it. Actually now those brakes are on my buddies Dana 60 in his Dart, now.
Moparlee
