Re: MP Distributor Help
[Re: torkrules]
#550699
12/11/09 02:11 PM
12/11/09 02:11 PM
Posts: 434 sweden
cuda-sweden
sweden
Do you have the newer MP or older unit
The only way to adjust the new style is to weld up the slots. he mean on the old style you have to weld up the slots
[Re: cuda-sweden]
#550700
12/11/09 07:28 PM
12/11/09 07:28 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Yes that's what I meant. It was really early in the morning.
[Re: six-barrel]
#550702
12/12/09 12:18 AM
12/12/09 12:18 AM
Posts: 4,762 Florida
BDW
Go to FBO website, they sell a wheel that fits in the distributor with 4 sets of slots that the weight pins slide in. No welding reuqired.
How can you tell if you have an old or the new type MP distributor?
[Re: BDW]
#550703
12/12/09 09:46 AM
12/12/09 09:46 AM
torkrules
I'm neurotic
I'm neurotic
Quickest way is to tell is to pull the rotor. If it has a brass colored rotor shaft it's the newer style. This is of course, the vacuum advance units.
[Re: torkrules]
#550704
12/12/09 10:30 AM
12/12/09 10:30 AM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
I have a MP distributor that I bought new about 8 years ago. It ended up having 59* of total timing. There is two screws under the rotor, Torx I think, I loosened them and could move an adjustable stop to limit total timing, then tighten the screws back up. Its been that way now for several years in the pulling truck.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
