purple shaft #550616
12/10/09 10:18 PM
12/10/09 10:18 PM
ontario canada
smallblock Offline OP
ontario canada
I got a purple camshaft for a 340 but dont know he specs . Is there a way to find out I found a number on it and it is 1136 but that is all I find I would like to know the lift and duration .
thanks
Re: purple shaft [Re: smallblock] #550617
12/10/09 11:55 PM
12/10/09 11:55 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
measure a cam lobe across the peak and at 90 degrees,multiply the difference by 1.5(rocker ratio)this will tell you lift
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
