49 dodge back on front burner #550417
12/10/09 05:27 PM
12/10/09 05:27 PM
SE Wisconsin
49wayfarer Offline OP
SE Wisconsin
Rotated the storage of my cars in the garage, and my 1949 Dodge Wayfarer is in my shop. been thinking about it, really want to start chopping it, but should get the ride height set too. 3" lowering blocks make the U bolts lower than the rims if I get a flat, and I really want to do a trangulated 4 link, but not enough $ yet. It has a Dakota front, but wondering, could I get away with cutting a coil on it, after I install the very heavy mopar BB of course. Unless I can find some used Dakota lowering spindles. How bad would a heavy engine on cut springs be?
Re: 49 dodge back on front burner [Re: 49wayfarer] #550418
12/10/09 05:37 PM
12/10/09 05:37 PM
SE Wisconsin
SE Wisconsin
I just picked up a 75 dodge 1 ton dually, with a 440. wondering, I need to fab all new front radiator supports, how about using the truck radiator, its brand new. Was thinking, I could just strip the truck and use everything, maybe the steering column and gauges.
Re: 49 dodge back on front burner [Re: 49wayfarer] #550419
12/10/09 05:46 PM
12/10/09 05:46 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Use as much as you can from a donor, within reason.
It helps keep costs down, and you remember the application easier!
As far a ride height, even a full gas tank can throw it off. That's one of those things yo uhave to wait on setting until it's a lot closer to done. You can block up the suspension on a coil spring to where you want, then order springs using the final weight, but with leafs it's pretty hard to approximate exact height.
Re: 49 dodge back on front burner [Re: RodStRace] #550420
12/10/09 06:21 PM
12/10/09 06:21 PM
SE Wisconsin
SE Wisconsin
Sitting here at work, checking out old HAMB posts. Really thinking of a 2-3" section and a 2-3" chop.
Re: 49 dodge back on front burner [Re: 49wayfarer] #550421
12/11/09 01:07 AM
12/11/09 01:07 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
heres a pic of a 49 dodge chopped,,ide kill to have this car,,my luck it has a CHEVY in it,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 49 dodge back on front burner [Re: fstfish66] #550422
12/13/09 12:03 AM
12/13/09 12:03 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A Chevy engine (and trans) should be real easy to unload, lots of people think they are the only engine made. Then a sb Mopar with either a 904 or a 727 should fit in the hole without much work.
Look at it this way, most of the hard work is already done. Gene
Re: 49 dodge back on front burner [Re: fstfish66] #550423
12/13/09 02:59 PM
12/13/09 02:59 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
ya that is sweet...i'd like that one too! remove the mouse and your all set.
