Re: Do these look ported to you?
[Re: HotRodDave]
#550279
12/11/09 02:18 AM
12/11/09 02:18 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
That's equivalent to an economy port. If you look down the intake runner you can see the guide is narrowed a bit. The rough edges have been smoothed and a half a-ed attempt at port matching was done. Depending on what the numbers were specifically, if they said 270 plus, did they give a pressure drop? Cause it would have to be higher than 28 inches of water. I've done 516's before and they don't flow easily. The exhaust numbers are believable, but looking at the pictures, I'm saying not likely, again, not at 28in. 150 for testing them is not bad. Basically 2 hrs of work. Tear down, clean up and flow. Possibly reassemble depending on condition. Good lower performance truck, quench heads.
[Re: viperblue72]
#550283
12/11/09 03:34 PM
12/11/09 03:34 PM
Posts: 2,255 IL
furious70
IL
thanks guys, gonna try to get them apart and some better pics soon.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#550284
12/11/09 09:30 PM
12/11/09 09:30 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
From the pics they definately have some work done on them, But not much IMO. The biggest negative factor that I see is that the Short turn doesnt appear to be touched at all. If it hasnt and it doesnt appear to be that will limit the heads flow to a max of 250 CFM IMO Dwayne from PHR schooled me on that. The Short turn is the key to getting the stock heads to flow over 240/250CFM. mike
