Re: How to lower a 1951 Plymouth without fab work .. [Re: fstfish66] #549839
12/26/09 04:24 PM
12/26/09 04:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Been down over 10 years now
Don't be the exception.
Re: How to lower a 1951 Plymouth without fab work .. [Re: Supercuda] #549840
12/30/09 12:25 AM
12/30/09 12:25 AM
Sandy, Utah
Robert R Offline
Robert R  Offline
Sandy, Utah
I am building a 50 Plymouth Suburban wagon right now just a year older than the one Damon did. I have already done the dropped uprights and am putting in a rack and pinion conversion from Fatman and a disc conversion from Rusty Hope. This looks like it should be an awesome combo. I just hope it goes straight and stops better
Currently building a 1950 Plym Suburban '70 340/A518 combo 1965 Dodge Dart Driver 1962 Jeep FC-170 1956 Nash Metropolitan
Re: How to lower a 1951 Plymouth without fab work .. [Re: Robert R] #549841
12/30/09 11:37 AM
12/30/09 11:37 AM
S.E. South Dakota !
bigdad Online content OP
Still Posting A Lot
bigdad  Online Content OP
Still Posting A Lot
S.E. South Dakota !
Great !!
post some pics and keep us updated on progress
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: How to lower a 1951 Plymouth without fab work .. [Re: bigdad] #549842
12/31/09 01:28 AM
12/31/09 01:28 AM
Sandy, Utah
Robert R Offline
Robert R  Offline
Sandy, Utah
I will try to get some pictures taken this weekend. Right now it is about 20 degrees for a high most days and I dont have insulation in the garage yet, so the heat doesn't do alot of good. The frame has been out to sandblast and straightening, painted and the front suspension arms are painted, new bushings and pivots and the fatman uprights and eaton springs are in. I need to get the machine work done to the spindles, king pin bushings and drill and tap some holes for the disc conversion. The rear springs are rebushed with poly bushings and installed with the rear in place but the spring perches are not welded yet until the engine and trans are in place to set pinion angle. This project is only about 2 years behind schedule, never had the intention to do a frame off for a driver, but it turned out to have been hit in the front left corner and bent the frame. I will start a new string for this next week and try to make at least some progress before the spring thaw
Re: How to lower a 1951 Plymouth without fab work .. [Re: Robert R] #549843
01/07/10 12:13 AM
01/07/10 12:13 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
they always seem to go farther then we orignally plan,,,i have heat in the garage but its been colder the nnormal here and i heat with oil,,,and we all know thats not cheap,,so ill wait till it warms up a little before i get to the garage,,,cant wait to see your pics.,..
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
