engine accessory noise, 2006 caravan
#549326
12/08/09 11:19 PM
12/08/09 11:19 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
has anyone ever experienced any whining noises coming from the accessory drive on a caravan? our '06, if driven at highway speeds for an extended period of time (greater than an hour) develops a noticeable whine on the passengers side. it varies with engine speed, not road speed, and it is very noticable in the cabin, but barely audible outside of the vehicle.
vehicle has 47k miles on it, I replaced the idler pulley last winter about 8k ago thinking that was it. it seemed to go away for a while, but it's back now. it seems to be more pronounced in cold weather. I'm thinking either power steering or water pump, since they're on the rear of the engine.
any help is appreciated.
Re: engine accessory noise, 2006 caravan
[Re: patrick]
#549328
12/09/09 01:48 PM
12/09/09 01:48 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
It could also be the tensioner pulley. I usually try to get a mech stethescope as close to the pully mounting area as possible to pin point the noise. Not easy with the engine running
[Re: WILD BILL]
#549329
12/09/09 03:32 PM
12/09/09 03:32 PM
patrick
Grand Haven, MI
that's what I assumed last winter, and that's why I replaced the tensioner pulley...the new one has less than 10k miles on it, I wouldn't expect it to go bad that quick.....
[Re: WILD BILL]
#549331
12/09/09 05:00 PM
12/09/09 05:00 PM
patrick
Grand Haven, MI
whoops, screwed up the original post. I replaced the tensioner pulley last go around. the I pulled the idler pulley off and couldn't hear any noise when spinning it and spun smooth. the tensioner pulley was a little more suspect at that time, I didn't really hear any noise, but when you spun it it felt rougher than the idler pulley.
[Re: Spode]
#549334
12/09/09 05:57 PM
12/09/09 05:57 PM
patrick
Grand Haven, MI
thanks for the ideas. spode, were you able to hear the noise with the belt off, spinning the WP by hand?
[Re: patrick]
#549336
12/10/09 04:45 PM
12/10/09 04:45 PM
Posts: 242 Upland, California
Spode
Upland, California
I almost bought a tensioner but I noticed the weep hole had some leakage and I had a lifetime warranty on the pump so I replaced it and the noise stopped.
[Re: patrick]
#549339
12/10/09 07:39 PM
12/10/09 07:39 PM
Posts: 327 wisconsin
mod381
wisconsin
It needs the power steering resovior replaced and fluid flushed. There is a filter in the resovior and after you drive it for a while it is plugging the filter and starving the pump for fluid,after you shut it off the fluid drains back and cleans the filter back out untill you drive it again.
[Re: mod381]
#549342
12/11/09 09:07 AM
12/11/09 09:07 AM
patrick
Grand Haven, MI
I'll try dig into it this weekend, does the whole reservoir need to be replaced, or just the filter?
Rockauto shows a couple different power steering filters on their website, that look like this
[Re: mod381]
#549344
12/20/09 04:48 PM
12/20/09 04:48 PM
patrick
Grand Haven, MI
thanks to everyone, especially mod381. replaced the resivoir, problem solved!
