Re: F1R Procharger recipes??
[Re: dakotahotrodder]
#549108
12/09/09 09:57 AM
12/09/09 09:57 AM
Posts: 2,286 Hamilton,Ont
72chrgrally
Hamilton,Ont
What kind of racing are you wanting to do with it? I'd love to have one of those BTW. Steve
Photobucket sucks
#549110
12/09/09 03:49 PM
12/09/09 03:49 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
IMO a procharger blowthrough deal would work good on a bracket car once you get it dialed in it should as good or better than NA combo plus it'll be more fun Whats your engine combo now????
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
#549115
12/09/09 06:48 PM
12/09/09 06:48 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Well, I have stock blocks, a girdle, aluminum main caps, etc., but was thinking of a better foundation. I've got the belt and pulley setup for 10 lbs of boost which should get me going. What are you doing with your rotating assembly, you have the small bore Koleno right?
a stock block has lasted me 300+ passes w/studs,girdle.i am putting the old assy in the new block.yes i have a small bore KP 1 of the very few i guess.
[Re: blownzoom440]
#549116
12/09/09 07:49 PM
12/09/09 07:49 PM
Posts: 642 South Dakota
dakotahotrodder
South Dakota
This procharger deal is pretty cool, but nothing beats a big old blower sticking a foot above the hood!
#549117
12/09/09 08:40 PM
12/09/09 08:40 PM
blownzoom440
ELYRIA,OH
Well, my car is 3700 with me. I wanted to get a Koleno block in std. bore instead of the 4.50 bore. None available right now though. I've got the complete unit, comp roller cam from the supercharger store, blower converter, big fuel pump, meth injection etc.. I have a good set of rpm heads, just not sure on stroke and rotating assembly. It should go a heck of alot faster than mid/high 10's, I run high tens/lo 11's with a 570hp 440 right now.
so what is the cam like[details]? my vert goes to 5500 off the line/4.10 gear.
#549123
12/09/09 11:07 PM
12/09/09 11:07 PM
blownzoom440
ELYRIA,OH
SWEET! where are the procharger dealers now to help you out.?!
