oversized valve stems #548243
12/07/09 03:30 PM
12/07/09 03:30 PM
Germany, Northcoast
Buschi340 Offline OP
Germany, Northcoast
... for X / J Heads. I read on some internet articles that I can use these instead of installing bushings to cure my side play probs. My problem now is that I can't find a (internet-) shop to buy them. That's the question, I need a source who offers valves with different stem diameters....
Re: oversized valve stems [Re: Buschi340] #548244
12/08/09 07:46 AM
12/08/09 07:46 AM
Germany, Northcoast
Germany, Northcoast
Nobody an idea?
Re: oversized valve stems [Re: Buschi340] #548245
12/08/09 09:27 AM
12/08/09 09:27 AM
Az
Crizila Offline
Crizila  Offline
Az
You realize that you are still gonna have to have the guides machined for the over-sized stems right?? - or try and ream them to size yourself - you will need to by the appropriate reamer. The guides don't wear out the same amount in all areas. They "bell" out at the top and the bottom and in an oval pattern. If the valve stems mike good and there is plenty of margin left for refacing them you are better off just having the guides rebushed. If the valves are worn out also, you are still better off buying stock size valves and having the guides rebushed - IMO.
Fastest 300
Re: oversized valve stems [Re: Crizila] #548246
12/08/09 09:47 AM
12/08/09 09:47 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
They used to be available in overized valve stems but don't know if they stil are. But the guides till have to be reamed to size.
Re: oversized valve stems [Re: Buschi340] #548247
12/08/09 09:52 AM
12/08/09 09:52 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'd rather stuff some new guides in it than putting even fatter stemmed valves in it. Did you consider knurling?
Re: oversized valve stems [Re: Buschi340] #548248
12/08/09 10:04 AM
12/08/09 10:04 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
If your valves are in good shape.
Your most economical approach would be putting some "guide liners" in there.
Your guide is opened up approx. .060" then the liner is pressed in and broached to size.
Bronze guide liners are .030" thick and will allow you to use your current valves with the proper clearence.
This process has been sucessfuly used in engine rebuilding for years. If done properly it will last for years also.
I would only do this for a "street" rebuild not a "race" motor.
Just my
Re: oversized valve stems [Re: roadhazard] #548249
12/08/09 11:57 AM
12/08/09 11:57 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Many years ago I had this done on some 273 heads. My problem was that both the guides and valve stems were worn out, so I had to buy valves anyway. It was much cheaper to have the guides opened up than it was to put guides in.
Re: oversized valve stems [Re: Buschi340] #548250
12/08/09 12:01 PM
12/08/09 12:01 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Check w/ Dan Dvorak at Dvorak Machine. You should be able to Google the name for their web site.
Re: oversized valve stems [Re: Buschi340] #548251
12/08/09 10:40 PM
12/08/09 10:40 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
Re: oversized valve stems [Re: Dartcuda] #548252
12/09/09 12:32 AM
12/09/09 12:32 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Even heavier valves? I'd get some +.100" long, small chevy valves and get .500" od guides installed for the smaller 11/32" stem. New retainers, springs and keepers and away you go. That's just my
