Re: How to identify a 440-6 longblock?
[Re: Commando1]
#548227
12/07/09 04:30 PM
12/07/09 04:30 PM
Posts: 581 Texas
Texican
Texas
Check the damper to see if it's a 6-pak crank. Not that it actually verifies the BLOCK, per se....
![](/ubbthreads/images/graemlins/iagree.gif) (IF) it's from a 70/71 Six pack, then it will have a different harmonic balancer - take picture of it or see if you can find numbers on it.
Check pad on top of block to make sure its a 440 HP Block (get all numbers on top of this pad: D440...e440...F440...etc...)
Check Vin number stamp on pad (side of block).
Check casting dates on the side of the block as well.
All of things will (help) ensure it's a real 6-pack engine, but the only way for sure is if the VIN matches a 6-pack car.
Don't be tooooo discouraged if it's not a real 6-pack engine. It still might be a good 440 HP engine and worth buying (if the price is right).
Good luck ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: Snoopy]
#548228
12/07/09 04:34 PM
12/07/09 04:34 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
I thought the only way to tell for sure, was to confirm that the stamped VIN on the engine matches a known 440-6 pak car.
I don't have the .jpg on this computer ... where's D. Pelliter ??
Yes that is the ONLY way to CONFIRM ...
[Re: JohnRR]
#548231
12/07/09 04:44 PM
12/07/09 04:44 PM
Posts: 581 Texas
Texican
Texas
Unless the pad on top of the engine pad indicated it was a (69) or more specifically a 69 1/2 six Pack engine which was internally balanced. Either way...I wouldn't get too excited if it was a real six pack engine, it still wouldn't bee any more valuable than a regular 440HP block... UNLESS IT HAD THE SAME VIN AS MY 70 CHallenger ![](/ubbthreads/images/graemlins/haha.gif) In which case I would gladly double his investment.
[Re: Texican]
#548232
12/07/09 04:45 PM
12/07/09 04:45 PM
Posts: 5,135 Kingsburg Calif.
Quikshft
Kingsburg Calif.
Well yes, if it happened to match my 70 Superbee I might pay a little extra for it as well. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Texican]
#548233
12/07/09 04:53 PM
12/07/09 04:53 PM
JohnRR
BUT the question above is about a 70 , I'm ASSuMEing the seller knows the difference ???? ...
