Page 1 of 3 1 2 3
welding race cars #547936
12/07/09 10:06 AM
12/07/09 10:06 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i wiuld like to start doing more of my on fab work on my RACE cars,things like mounting 4 link brackets,wheely bars,frame conectors,stuff like that.if you had to buy a mig or tig what would you be looking at?im not looking to do this as a buisiness just my own personal race car stuff or somthing once in a whill for a buddy.
Re: welding race cars [Re: bonefish] #547937
12/07/09 10:15 AM
12/07/09 10:15 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
If you don't have welding exp. then go MIG. you cant go wrong. I have both and 9 times out of 10 I use the mig. Much easier to self teach.
Re: welding race cars [Re: bonefish] #547938
12/07/09 10:16 AM
12/07/09 10:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use Lincoln welders, I have a 220 version mig but
the day I bought it I bought a heavier gun and cable
for it... the one that comes on it is pretty wimpy.
I also have their tig unit. I would suggest a brand
name unit so you can get parts for it easy
Re: welding race cars [Re: MR_P_BODY] #547939
12/07/09 10:23 AM
12/07/09 10:23 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i was lookin at the lincolns and millers ,but really dont know witch modle would suite my needs,i have a little lincoln mig pac 10,it works great for thin brackets and such but what specs or modle #should i be looking for to meet my needs?
Re: welding race cars [Re: bonefish] #547940
12/07/09 10:37 AM
12/07/09 10:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a 170T but its a few years old... I would look
at 170 to 195 range.... that'll do most anything
for a hobbyist... make sure you get the bottle
attachment... dont waste your time with core wire
Re: welding race cars [Re: MR_P_BODY] #547941
12/07/09 10:47 AM
12/07/09 10:47 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
thanks,yeh that core wire system stinks i have the bottle.
Re: welding race cars [Re: MR_P_BODY] #547942
12/07/09 10:51 AM
12/07/09 10:51 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Buy the biggest you can afford. I have a Miller 210 mig and a Miller Syncrowave 250DX stick/tig. At some point I will buy a Miller 252 mig though.
Re: welding race cars [Re: justinp61] #547943
12/07/09 11:03 AM
12/07/09 11:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would like to buy a bigger tig... something in
the 250-300 range... when I'm welding on intakes
I have to pre-heat alot of them
Re: welding race cars [Re: MR_P_BODY] #547944
12/07/09 11:10 AM
12/07/09 11:10 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
If you were to learn one type of welding and had not much previous experience, I would definetly buy a tig. Much more versatile, you cant weld chrome-moly with a mig, or most other metals other than just good old mild steel. I am also of the opinion that to learn to tig is much easier, but that is jsut my opinion
Re: welding race cars [Re: joshking440] #547945
12/07/09 11:22 AM
12/07/09 11:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mig welding is much easier(IMO), I do all of it but
if you can move you hand and get the sound of bacon
frying you are mig welding... it'll weld moly, mild, and SS
Re: welding race cars [Re: MR_P_BODY] #547946
12/07/09 11:49 AM
12/07/09 11:49 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Don't forget aluminum.
Re: welding race cars [Re: justinp61] #547947
12/07/09 12:00 PM
12/07/09 12:00 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
TIG welding can be extremely difficult to do if you are laying on your back under a car, you would need a thumb control because you can't be pressing the pedal while laying down.
Re: welding race cars [Re: bonefish] #547948
12/07/09 12:33 PM
12/07/09 12:33 PM
Az
Crizila Offline
Crizila  Offline
Az
Unless you do it for a living or do it alot, M.I.G. is the way to go. Forgiving, easy to learn, good for out-of-position welding. Go with a gas system verses flux core. I bought a used HTP 140 a few years back. Runs off of 110, has pause and weld time controls ( stitch welding ) and can easily weld up to 1/4". Makes an amateur ( that would be me ) look good.
Fastest 300
Re: welding race cars [Re: justinp61] #547949
12/07/09 12:33 PM
12/07/09 12:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah that also but you need a separate liner or
another cable... I was just referring to simple stuff
but the mig is a very versatile machine
Re: welding race cars [Re: MR_P_BODY] #547950
12/07/09 12:57 PM
12/07/09 12:57 PM
Az
Crizila Offline
Crizila  Offline
Az
Yes, it is a little more of a hassle switching between steel and aluminum. If you do a lot of aluminum work too, your best bet is to buy a complete seperate cable / liner and gun all set up for the aluminum wire size you normally use. Don't scimp on the helmet ether. Auto-darkening for sure and get one with a big lense ( especially if you ware glasses )that has adjustable darkening, sensitivity and delay features. Mine is a "Kobalt". Probably one of the least expensive helmets that still has all the above mentioned features.
Fastest 300
Re: welding race cars [Re: Crizila] #547951
12/07/09 01:02 PM
12/07/09 01:02 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Now i am pretty sure that to weul chrome moly and have it certify, it must be tigged, and if you ever want to weld stainless or aluminum and have it look really good you need to tig it. but just my opinion
Re: welding race cars [Re: joshking440] #547952
12/07/09 01:15 PM
12/07/09 01:15 PM
Az
Crizila Offline
Crizila  Offline
Az
Don't know about the certification thing, but no two ways that T.I.G. is the way to go - in the hands of a professional. I am no where near an expert when it comes to welding ( or metalergy ), and I would not attempt to weld up a $2K set of heads, etc, but I would have no qualms about welding up suspension stuff - from a strength standpoint.
Fastest 300
Re: welding race cars [Re: joshking440] #547953
12/07/09 01:20 PM
12/07/09 01:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes if you have a moly cage/chassis it must be tigged
but I was saying that you can weld all types of materials
Re: welding race cars [Re: MR_P_BODY] #547954
12/07/09 04:55 PM
12/07/09 04:55 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a spool gun and my Miller has the "gun on demand" feature. So which ever gun I pick up it's always hot.
Re: welding race cars [Re: bonefish] #547955
12/07/09 06:09 PM
12/07/09 06:09 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Maybe one of the pro-welders out there can answer this: I always thought the reason that chrome moly could not be migged because mig uses a 'mild steel' rod and/or w/copper coating and that the mixing/welding together of mild steel or other metals not similar to chrome moly causes weld embrittlement. So why not MIG with chrome moly wire instead?
Page 1 of 3 1 2 3
