U-Joints #547127
12/06/09 05:14 PM
12/06/09 05:14 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
anyone know yoke diameter for universal joints based on this:
1976 Cast 440 with 727 (C-body)
rear is stock early 71 (aug 70) 8.25 rear
or am i going to need to disassemble, measure and then buy parts?
thanks
'71 Satellite Sebring 440
Re: U-Joints [Re: landon1] #547128
12/06/09 05:57 PM
12/06/09 05:57 PM
scratchnfotraction Offline
2 1/8" = 7260
2 5/8" = 7290
3 5/8" = 1330
most likly and 7260 x 7290 conversion joint if they dont match
but might get lucky and both be the 7260
I run a 7260 x 1330 conversion joint napa# 240-0457
did it have a drive shaft cut to fit for the swap?
Re: U-Joints [Re: scratchnfotraction] #547129
12/06/09 06:11 PM
12/06/09 06:11 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
no idea - the swap was done probably before i was even born
Re: U-Joints [Re: landon1] #547130
12/06/09 06:17 PM
12/06/09 06:17 PM
most 8 1/4 rear axle I have seen had the 7260
but the c-bodys could be both 7260 or 7290
looks like you will have to at least look under there
the 7260 are kinda small looking,thats what I look for when checking
