Any experiences/opinions on Hedman Hedder #78070 #546748
12/05/09 11:18 PM
12/05/09 11:18 PM
SeventySatellite Offline OP
Thinking about getting a set for my 383. The instructions state that the transmission linkage may need to be modified and also for a mini starter to be used. Anyone here have any experiences/opinions with these headers?
Re: Any experiences/opinions on Hedman Hedder #78070 [Re: SeventySatellite] #546749
12/06/09 12:15 AM
12/06/09 12:15 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
well if you don't want to do that then run em out the side of the fender before the body woork done
can't say..here's a
looking good by the way
Re: Any experiences/opinions on Hedman Hedder #78070 [Re: SeventySatellite] #546750
12/06/09 02:28 PM
12/06/09 02:28 PM
Re: Any experiences/opinions on Hedman Hedder #78070 [Re: SeventySatellite] #546751
12/06/09 05:36 PM
12/06/09 05:36 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
I have those on my 383 auto 66 coronet. they fit ok,I didnt have to bash em anywhere. I forget which side is close to the trans pan and #6 plug is close to the pipe.shift linkage clears easy but im column shift,so they are probably talking console shift linkage.hope this helps.
cb
Re: Any experiences/opinions on Hedman Hedder #78070 [Re: SeventySatellite] #546752
12/06/09 05:45 PM
12/06/09 05:45 PM
north carolina
K
kwik63 Offline
kwik63  Offline
K
north carolina
I ran them on my 63 440 savoy and 67 440 GTX. The GTX is a 4 speed and the Savoy has aftremarket t-flite race shifter. The directions mention alterations to automatic shift linkage, but it did not apply to my applications. Lightweight starter is the only way to go. The 78070 is a great header for the price.
Re: Any experiences/opinions on Hedman Hedder #78070 [Re: SeventySatellite] #546753
12/06/09 05:54 PM
12/06/09 05:54 PM
Spartanburg SC
MoparDan Offline
MoparDan  Offline
Spartanburg SC
as mentioned the headers are good for the price; if your car is steering column shift..get TTI's troque shaft assembly ($41.00) makes the install easy.
Re: Any experiences/opinions on Hedman Hedder #78070 [Re: MoparDan] #546754
12/07/09 01:23 AM
12/07/09 01:23 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I really dont remember the part# on these 1-3/4 Hedman headers on the 440 in my 63 Sport Fury. They fit great with no mods at all but I do use a cable shifter and the mini starter. Ron
