Page 2 of 3 1 2 3
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: dart4forte] #546500
12/06/09 08:38 PM
12/06/09 08:38 PM
fresno
hyefatman Offline OP
fresno
thanks for the help - i add 2 1/8 shims to the
2 bolts closest to the motor 4shims total - that moved the steering box away from the headers and toward the fender -- almost a 1/4 of a inch move -- just hope its safe because if the shims come off i will be in a world of hate ---
now on a personal note
i have worked on my mopars for 30 years now i am 45 years old started with a 1970 sublime barracuda grand coupe and 1968 dodge charger
when i was a kid i saved my money up for a set of hooker headers- almost 100 bucks which was a ton of $$$ ...those headers gave me so my problems i dont have enough space or time to write it all down- but people my age know what i am talking about...now today i am a adult and will NOT stand
for a company to out right lie to me.. TTI tech and the dealer knew i did not have a stock kframe
and knew i had power steering--they both said no
modification needed PERIOD... as far as i can tell the web site says nothing about replacing
the steering coupler or shimming the unit -- if
this is a fix why not explain this to the customer ---why do i have to come to moparts for tech support - well thanks love moparts.com
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: hyefatman] #546501
12/06/09 08:58 PM
12/06/09 08:58 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Mine is a SB but what TTI said in their instructions was to have the engine position in the specifications that they sent. I did that by shimming and repositioning the engine, and mine fit fine.
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: hyefatman] #546502
12/06/09 09:19 PM
12/06/09 09:19 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I just thought of something If Hemispherical Reproductions made your K frame out of a B-body core, your steering box sits at the wrong angle. B & E body k frames will physically bolt into either car and work with everything bone stock. But throw something like headers that might have a very close tolerance into the mix, and it could possibly cause the problems you are experiencing. In a B-body, the steering box points upwards to the rear at a greater angle than does an E-body steering box. I know it may sound like I'm taking up for TTI,which I'm not...I just wanted to give you more info that I thought of. Oh, and I'm 52...and know EXACTLY what you mean about headers back in the day! Good luck
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: JDMopar] #546503
12/06/09 09:35 PM
12/06/09 09:35 PM
fresno
fresno
"If Hemispherical Reproductions made your K frame out of a B-body core".... that a interesting point..
i went with newcoms because i had a stock b body hemi k frame that i took out of the a ebody hemi clone car and bought what i thought was a ebody unit from newcoms i did not want any problems with the application that why i know TTI knew about my kframe .. it took 6 months to get that k frame from that company
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: hyefatman] #546504
12/07/09 12:30 AM
12/07/09 12:30 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
it also looks like the header is just touching the
steering box --do i take a hammer to it
I would try and shift the engine 1st. Headers are always a pain, but worth the effort imo. I had to use a Dremel tool and grind some casting numbers off the side of my PS box to get my Doug's to fit rather than dent the head pipes. You need very little clearance on the drivers side because the engine torques away from everything.
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: Lefty] #546505
12/07/09 01:33 AM
12/07/09 01:33 AM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I put the TTI's on my 69 Dart with a 340 and had some minor clearance issues, so I made some 3/8 or 1/4 spacers (cant remember right off) to raise the motor up a little and that worked fine. You cant see them so it looks stock. Also I was told by a TTI rep. that not all stock K-frames are welded exactly the same so there might be some minor issues there also. Good luck!!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: G-Money1320] #546506
12/07/09 05:22 AM
12/07/09 05:22 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i bet its just all the tolerances stacking up, these cars where not made perfect in the first place and i gues it only gets worse after 30+ years of abuse..
and trust me stock replacement enginemounts are nowhere near perfect, i had a slight clearence problem with my tti headers also but on a smallblock abody when i put in new engine mounts and gues what, i put in my old original mounts and it made a whole world of diference...
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: 1Fast340] #546507
12/07/09 07:40 AM
12/07/09 07:40 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I just went thru a wresting match with TTI's on a 440 in a 70 Charger. The car has been hit in the front in it's previous life as indicated by the wrinkles in the inner fenders back by the hood hinges. Eventually I got things to fit. The right side engine mount has a 1/8 shim under it & it now has a stock trans mount...
Try this: Remove the thru-bolts for the engine mounts and carefully jack up the engine on each side and set it back into the k frame. After a lot of head scratching I tried it and it helped.
Be sure if you have an aftermarket trans mount that it is not taller than the stock one.
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: hyefatman] #546508
12/07/09 10:43 AM
12/07/09 10:43 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
ARE YOU USEING THE THE STOCK THROUGH BOLT ON THE DRIVERS SIDE ?
If you want try this remove the drivers mount and buy a set of steel $14.00 mounts and install only the drivers side with a hardware store grade 5 though (long ) bolt in 5/8 inch size , this will cause the motor to be slightly higher on the drivers side and very strong also we have been running a 440 4speed b-body like this for years and also a 426 aluminum block hemi in a 71 challenger like this also no problems .
1969 Dodge Charger 1969 Dodge Superbee
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: cjs69mope] #546509
12/07/09 10:49 AM
12/07/09 10:49 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Do they make a solid mount for the HEMI sytle mounts ?
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: JohnRR] #546510
12/07/09 10:54 AM
12/07/09 10:54 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
OK. It's Monday. What does TTI say?
E-Body guys maybe should go to E-Body exclusive sites for advice. Seem to have more problems than B or others here. My B TTI's are fine. I'm just saying...
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: DennisH ] #546511
12/07/09 11:01 AM
12/07/09 11:01 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Is TTi even open yet? It's only 7 am on the LEFT COAST ...
I know EXACTLY what they are going to say ...
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: JohnRR] #546512
12/07/09 11:08 AM
12/07/09 11:08 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Me too.
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: Challenger 1] #546513
12/07/09 12:18 PM
12/07/09 12:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
blah blah blah, for what they charge they should install themselves. for some they work great and for others not so much. The fact that the car or engine has dropped 1/32 of an inch shouldn't effect fit. I know 2 guys that bought complete kits that had huge fit issues. Jeesh I'd expect it form a $230 kit but not a $1000+ kit.
Good luck, I hope they don't recommend swapping mounts, changing column and so on.
Coming soon!!!!
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: Mr.Yuck] #546514
12/07/09 01:04 PM
12/07/09 01:04 PM
DennisH Offline
Vacation
DennisH  Offline
Vacation
Caveat Emptor. Don't like em? Don't buy em. Do your research.
Overpriced? Yes. Cool under the hood, 6 years no problems.
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: DennisH ] #546515
12/07/09 01:05 PM
12/07/09 01:05 PM
DennisH Offline
Vacation
DennisH  Offline
Vacation
It's after 9 on the whacky lefty Coast now.
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: Mr.Yuck] #546516
12/07/09 07:27 PM
12/07/09 07:27 PM
NC
DCM71cuda Offline
DCM71cuda  Offline
NC
If they don't make/design them for a 'stock' installation, what else would they have to base the design on?
If your engine is not in a stock location, and your engine components are not in a stock location, how can you possibly blame tti for that??
Because if they fit nicely in your 'non stock' location, then they probably would not fit anything else.
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: DCM71cuda] #546517
12/07/09 09:34 PM
12/07/09 09:34 PM
fresno
fresno
ok- called TTI and they said that some installs
have this problem - i can try to loosen trans mount
and try to move it toward the pass side- or i can shim the motor mount at the point where it connects to the motor or add a shim to the motor mount pad--- for some reason he did not recommend
Shimming the power steering box ...called Schumacher’s and he said i should add a 1/4 shim
to the motor mount but i think i would have to remove the 3 studs and find bigger ones - thats going to be killer - maybe i do a little of every
thing using 1-8 shims
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: hyefatman] #546518
12/07/09 10:59 PM
12/07/09 10:59 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Where did your application's measurements fall with regards to the measurements provided by TTI for the crank centerline in relation to the K-frame. I didn't see that in the above posts.
I used a set of Mighty Mounts in my e-body(440 block) and I believe they lifted my moter upwards slightly as my shaker is up pretty tight to the hood. I only have 2" TTi's and an RB with regular port Indy 440 EZ's though.
Re: tti exhaust headers do not fit !!!! hits cuupler [Re: DCM71cuda] #546519
12/08/09 10:15 AM
12/08/09 10:15 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I don't know but I've used cheap headers and mid price headers on many BB B-bodys and have never had to dimple, ding or bend them. None of them dragged or had extensive leaks as many claim on this site. The thing you have to do is TAKE your time, get the motor up, steering column out and most fit pretty easy. for somebody to charger $6-700 for a set of headers is crazy. The 72 340 swinger I had had a set on it. Nice yes, but after 3 years of driving they looked like any other header out there. I put a set of Summit headers on my bro's 318 67 sat in about 30 minutes. (mani's off, engine up and column in the car. The fact that a car..or the cars engine has dropped a tad should have that much of an impact on your headers. I'm guessing from the factory they had a + / - on engine height.
Page 2 of 3 1 2 3
