Wiould 295 65 15 tires fit under a 1970 Dodge Coronet #546260
12/05/09 06:23 PM
12/05/09 06:23 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hi Guys
I'm just wondering if a set of 295 65 15 Bf Good rich T/A drag radials would fit under the rear quarters on my 1970 Dodge Coronet. 15/8 inch rim and standard back spacing .
295 50 15's fit fine.
Anyone run these on their car?
Mike
1969 Dodge Dart Swinger
Re: Wiould 295 65 15 tires fit under a 1970 Dodge Coronet [Re: MikeyT] #546261
12/05/09 06:28 PM
12/05/09 06:28 PM
Sidney Ohio
9SecRoadRunner Offline
Sidney Ohio
tried a 295/50/15 on an 8.5" wheel with a 4.75 back space and it rubbed, this was on a 70 Bee, went to a 275/60/15 and its got plenty of room
You Thinking It's So Doesn't Make It a Fact
Re: Wiould 295 65 15 tires fit under a 1970 Dodge Coron [Re: MikeyT] #546262
12/05/09 06:30 PM
12/05/09 06:30 PM
Oakley CA
69charger440_6pa Offline
Oakley CA
They will fit but you must use the correct back space wheel. Also you will need to be aware of your ride hight. That's a tall tire and if your lowered too much it could rub
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
