A little help PLEASE??????????? #545343
12/04/09 07:37 PM
12/04/09 07:37 PM
TN
65racer Offline OP
2009 IHRA World Champion
65racer  Offline OP
TN
Guy's I am in the process of freshening the engine in the car, had another block done, and was checking everything out, and found the
intermediate shaft bushing has cracked in the block, I drove it out and it came out in 2 seperate pieces, sooooooo I am going to have to replace it.
I checked Mancini's site, and they list several one's for mopars, is there a difference in these things, or are they a one fits all deal, this is the first time I have had to replace one of these.
And another ?????? do these just drive back into the block, or is there some black magic deal that has to be done with it.
I have looked around the shop, I feel like I should have one of these somewhere, as I like to try and keep extra parts around, but haven't found it yet, so I may just have to order one.
Re: A little help PLEASE??????????? [Re: 65racer] #545344
12/04/09 07:42 PM
12/04/09 07:42 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well as far as I know all the bushing are the same ..but once you drive it in it need to be resize or you shaft is not going to fit. they make a tool to take out and put in and resize..
Re: A little help PLEASE??????????? [Re: VernMotor] #545345
12/04/09 08:05 PM
12/04/09 08:05 PM
organ
maximum entropy Offline
organ
i've always used an oil pump drive to size the bushing. i spin it with a speed handle and it loosens up in just a few minutes. never had any problems with them. i almost always replace it. done tens of millions of them. maybe hundreds of millions. billions?
Re: A little help PLEASE??????????? [Re: maximum entropy] #545346
12/04/09 08:20 PM
12/04/09 08:20 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Re: A little help PLEASE??????????? [Re: VernMotor] #545347
12/04/09 08:46 PM
12/04/09 08:46 PM
Iowa
I
ironjay Offline
ironjay  Offline
I
Iowa
Davey--Just put it in with a old pump drive, that way when it goes in it won't distort. Good luck Jay-------
Re: A little help PLEASE??????????? [Re: VernMotor] #545348
12/04/09 08:57 PM
12/04/09 08:57 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Here is the tool I use
http://www.handsontools.com/OTC-6293-Distributor-Bushing-Installer-Reamer_p_6498.html
My If you don't have access to this installer, use the bushing that Ryan once alluded to. It was a Napa part number, that had the "crush" factored into the o.d. If you drive in that mopar bushing without the factory burnisher, I don't care what you will hear, it could be too tight. That tool actually takes off material on the way out. Hopefully Ryan will chime in.
Re: A little help PLEASE??????????? [Re: Leigh] #545349
12/04/09 09:38 PM
12/04/09 09:38 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There are two bushings,one babbit/aluminum and one bronze.AS mentioned use an old shaft to drive it in.
Re: A little help PLEASE??????????? [Re: B G Racing] #545350
12/05/09 05:17 PM
12/05/09 05:17 PM
TN
65racer Offline OP
65racer  Offline OP
TN
Thanks guy's, found one in the shop, got it installed, worked out fine, slicker than snot on a door knob, also fit the cam bearings, and got that taken care of, now it's time to r&r and back at it tomorrow.
