Degree wheel pointer #545291
12/04/09 06:31 PM
12/04/09 06:31 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Could someone point me toward something nicer than a bent piece of coat hanger that Comp Cams sells with their big aluminum degree wheel?
Re: Degree wheel pointer [Re: Scamp451] #545292
12/04/09 06:34 PM
12/04/09 06:34 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Check your PMs.
RIP Monte Smith
Re: Degree wheel pointer [Re: CompWedgeEngines] #545293
12/04/09 06:40 PM
12/04/09 06:40 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Your inbox is full, I tried to reply. Do they have a website, or do you have a P/N?
This is the only "tool" I found when I Googled the manufacturer.
Re: Degree wheel pointer [Re: Scamp451] #545294
12/04/09 07:01 PM
12/04/09 07:01 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... a bent piece of coat hanger...
Uhhh... that's all I ever use. Oh, and a bolt & washer to attach it to the block.
Re: Degree wheel pointer [Re: BradH] #545295
12/04/09 07:27 PM
12/04/09 07:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Same here.... a piece of 1/16" tig rod(I dont have any
coat hangers in the shop)
Re: Degree wheel pointer [Re: BradH] #545296
12/04/09 07:30 PM
12/04/09 07:30 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Don't let your wife catch you stealing coat hangers....
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Degree wheel pointer [Re: Scamp451] #545297
12/04/09 07:42 PM
12/04/09 07:42 PM
AndyF Offline
AndyF  Offline
Here ya go. I have some other tricks to, I'll look around for another picture.
Re: Degree wheel pointer [Re: AndyF] #545298
12/04/09 07:44 PM
12/04/09 07:44 PM
AndyF Offline
AndyF  Offline
Another setup for the smaller wheel.
Re: Degree wheel pointer [Re: AndyF] #545299
12/04/09 07:47 PM
12/04/09 07:47 PM
AndyF Offline
AndyF  Offline
Another view showing the pointer as well as the tool that holds the dial indicator over the lifter bores.
Re: Degree wheel pointer [Re: AndyF] #545300
12/04/09 08:43 PM
12/04/09 08:43 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i like the dial indicator stand.does the indicator have a long stem,or is it on the pushrod?are they for sale?
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Degree wheel pointer [Re: AndyF] #545301
12/04/09 08:44 PM
12/04/09 08:44 PM
UK
602heavy Offline
602heavy  Offline
UK
Re: Degree wheel pointer [Re: 602heavy] #545302
12/04/09 08:49 PM
12/04/09 08:49 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I always use a tig rod. Never had an issue. Double and triple check always come up with the same numbers.
You don't need anything fancy to degree an engine...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Degree wheel pointer [Re: BradH] #545303
12/04/09 08:50 PM
12/04/09 08:50 PM
Az
Crizila Offline
Crizila  Offline
Az
Me 2. I take it from my wifes side of the closet - Shhhhhhh. NO, IT AINT SPRING YET!!
Fastest 300
Re: Degree wheel pointer [Re: Crizila] #545304
12/04/09 09:01 PM
12/04/09 09:01 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Same here, I just beat a thin flat spot into it parallel to the lines on the plate. Easier to bend the pointer than loosen the bolts and move the wheel (or pointer).
Re: Degree wheel pointer [Re: Sixpak] #545305
12/04/09 09:20 PM
12/04/09 09:20 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
Small block rigged up...my wife never has any extra hangers, and I can't afford a Tig!
Re: Degree wheel pointer [Re: ETASPEN] #545306
12/04/09 09:27 PM
12/04/09 09:27 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Coat hanger so I can just bend it and not move the wheel
I wouldn't mind having a dial indicator stand as shown. Getting mine positioned right is the hardest part of the job.
I want my fair share
Re: Degree wheel pointer [Re: SomeCarGuy] #545307
12/04/09 09:56 PM
12/04/09 09:56 PM
sg66mopar Offline
sg66mopar  Offline
Dude, I was a machinist for years and worked to 2 tenths all day long. Coat hanger here too. Bend it all over and put it just where it needs to be in a matter of seconds.
Re: Degree wheel pointer [Re: MR_P_BODY] #545308
12/04/09 09:59 PM
12/04/09 09:59 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Me three ,and they are totally adjustable and come in different colors
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Degree wheel pointer [Re: hemi-itis] #545309
12/04/09 10:02 PM
12/04/09 10:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats some nice pointers Andy. Andy what make is that big blue degree wheel ? I have the white Comp wheel which works good but I like the larger one better. Ron
Re: Degree wheel pointer [Re: hemi-itis] #545310
12/04/09 10:16 PM
12/04/09 10:16 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Now thats a piston stop!
