Re: hard brakes on a 1969 Charger
[Re: Dabee]
#544294
12/03/09 10:45 PM
12/03/09 10:45 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I had a '71 Duster, manual disc brake car, no booster. Brake pedal stayed low and brake lights stayed on. Master cylinder was bad.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: mopar_leaner]
#544296
12/03/09 10:54 PM
12/03/09 10:54 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
It could be air in the system,bad master cyl.,bad booster, drum brakes out of adjustment or not enough vacuum because of the cam (at low speeds/idle) ,,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
[Re: mopar_leaner]
#544300
12/03/09 11:06 PM
12/03/09 11:06 PM
bigD
Hatfield,Pa.
Go down to the local autoparts place and p/u a vacuum gauge,then find some place to tap into on the carb(not the distributor port on the side of the carb),preferably on the base plate or vacuum Tee the go's to the brake booster,D.
[Re: dave571]
#544305
12/04/09 12:45 AM
12/04/09 12:45 AM
RapidRobert
You might split the M/C/booster & (eng idling) hit the brake & if still acting up that eliminates the M/C as the problem but see what the pushrod clearance is while you are in there & might see if the check valve is available seperately if it itself turns out to be the culprit.
[Re: Crizila]
#544309
12/04/09 11:24 AM
12/04/09 11:24 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Air in the system will give you a mushy pedal.Low vacuum or bad booster gives you a hard pedal.Rocky
Chrysler Firepower
