Page 2 of 3 1 2 3
Re: Indy Legend or Stage 5? #544046
12/03/09 11:08 PM
12/03/09 11:08 PM
just out of curiosity, a question for those of you building your combos's with the heads mentioned. how big is the cam your running and at what compression ratio?
indy legend heads, cnc ported, indy offset crossram intake,heads flows 450 cfm, .737 lift solid roller cam and 11.2:1 compression.runs mid 9's on pump gas and a spritz of 110 race fuel.
Re: Indy Legend or Stage 5? #544047
12/03/09 11:17 PM
12/03/09 11:17 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I gots me a .466+ lobe lift flat tappet from Barton that will go in first...Then a Old crane grind which has about .475 lobe lift roller. I say this cause i dont know what ration these rocker arms are, some say 1.6 some say less.
Compression is 14:1
Just a friendly debate, I dont get worked up over the internet...I laugh a bunch more than most normal people
Its winter time dang it....and I havent raced but twice in almost a whole year...now im starting to get mad.
Do i win a prize Dan-O for the largest flat tappet on the web site or something...
I guess it would be funny if I was running a .500 lift cam talking about all this flow.
Re: Indy Legend or Stage 5? #544048
12/03/09 11:19 PM
12/03/09 11:19 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
.664" (.423" lobe), 11:1
My motor isn't going to use the heads full potential. just there in case I want to later.
any ways I have the custom heads, mine can be ported even further and it has the dual plug capability
Re: Indy Legend or Stage 5? [Re: Defbob] #544049
12/03/09 11:29 PM
12/03/09 11:29 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I agree completely with cre!
The flow bench dyno nationals.
They are just tools
I'm running a .650ish" roller. 9.0:1 procharged.
Re: Indy Legend or Stage 5? [Re: The Shadow] #544050
12/03/09 11:34 PM
12/03/09 11:34 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
They are just tools
I dont believe I want any of that engine on a dyno contest...I recall what it made power wise..
Re: Indy Legend or Stage 5? #544051
12/03/09 11:38 PM
12/03/09 11:38 PM
Hemiroid Offline
Hemiroid  Offline
Had a set of raised exhaust port St.V's done by Jeff @ MCH, 490 CFM int., 326 CFM exhaust. Was going to use .950ish lift and 15.5 comp but sold it all to go another direction
Re: Indy Legend or Stage 5? [Re: Hemiroid] #544052
12/03/09 11:43 PM
12/03/09 11:43 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
What would you guys see dyno wise between the raised port design heads with a full port job, compared to these SR type heads....If looks would kill the exhaust side it self would be the executioner...
would there be 50 hp diff?
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544053
12/04/09 12:15 AM
12/04/09 12:15 AM
Compression is 14:1
well, if i was going to give you a prize for that flat tappet that'll end up around .755 lift, it wouldn't be anything to be proud of.
by the way, the S/R heads won't even come close to the power potential of the raised port big valve or millenium stage 5's.
the reason i asked about the cams and combo's is because the supposed 10 cfm difference doesn't amount to squat. until you build something of real potential, it's meaningless and not even worth worrying about.
for example, go ahead and run that silly flat tappet cam and somebody else running a well designed roller 10 degree's smaller with 10 less cfm will put you on the trailer. see my point?
Re: Indy Legend or Stage 5? #544054
12/04/09 12:24 AM
12/04/09 12:24 AM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Very well said......
Re: Indy Legend or Stage 5? #544055
12/04/09 12:58 AM
12/04/09 12:58 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Compression is 14:1
Oh
I see..so flat tappet cams are silly...hmm thats a different way of putting it.
Let me ask you this...Do you base all flat tappet cams in the silly category?
So does a Hyd flat tappet cam fall in the stupid column? Or are they grouped together as one big silly family?
To be Honest the only reason im not running the roller is cause I dont have the money for a good set of roller lifters, roller springs etc.. Just to be clear...
Im currently Un-employed. And I currently have the "Silly" flat tappet stuff
BTW how does flow rates and cam style having any thing to do with cutting a light in bracket racing
If Im not mistaken I was thinking that was kind of a Cheap shot towards me Dan..So let me ask you, do you think Im just silly in general?
Your opinion is obviously very important to me
I think I will call up Comp Cams and ask them why they even bother grinding those flat tappet cams..
Now I know the raised port hemi heads rule...kinda why I ask...I was looking for a more In depth answer than just
I dedicate a new sig line just for you Dan-the-man
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544056
12/04/09 01:24 AM
12/04/09 01:24 AM
Bob,
you completely missed the point and instead your taking my comments as a personal attack or something.
if you want to know why i think the cam you mentioned is silly, call me and i'll explain it to you.
i guess if every post i make isn't a PC atta boy, you betcha, this is what i should expect.
Re: Indy Legend or Stage 5? #544057
12/04/09 02:47 AM
12/04/09 02:47 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
i guess if every post i make isn't a PC atta boy, you betcha, this is what i should expect.call me and i'll explain it to you.
Naa
I take your advise very seriously Dan, I think honestly you generally want to help people, and offer good advise...
Ill keep the Barton Custom Grind "silly cam" (Bullet Racing)..
He assure me he has some practice developing a max effort solid flat tappet cam...
I would imagine he has spent more time on the dyno testing Hemi cams as about anyone.
Let me ask you this though...
I cant seem to find any were in this thread where I posted any specs other than lobe lift..but your so sure that it's a poor cam choice, and yours would be better correct? How much time honestly have you spent on the dyno with a Hemi engine developing a flat tappet Max effort cam?
He told me he has a fortune in scrap short iron in the attic with tested flat tappet cores.
He actually told me that it works with power brakes. LOL..
He was pretty secretive with the cam profile, and wouldnt actually tell me the valve events until I payed for it LOL..
He also told me this is the cam you get in a few crate engine including a 528 pump gas Hemi with 9:1 compression that makes 650+ hp on 87 octane fuel...
I have also spent some time on the phone with Harold the cam guru that works for Bullet, that designed a bunch of cams for UltraDyne. He worked with those guys in this and a few cams developments.
Thanks for the offer though.
This will be my last post on this topic, and have talked with a few guys through Pm's about what I was trying to get across in this thread. (I will reply tomorrow guys).
In a nut shell, every time these MP heads are mentioned...many comments about how there junk, seats falling out etc...we have all read these comments.
And I dont blame them for being mad or PO'd..But these are not no where near the same head, same casting, same machine work, or even from the same foundry as older versions.
Thats all, just a good quality, cheap alternative hemi head...If not the cheapest available.
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544058
12/04/09 05:30 AM
12/04/09 05:30 AM
Europe
BB 70 Challenger Offline
Europe
Thanks for the flow numbers.
Does anybody know the following:
- how much do StageV replacement heads flow out-of-the-box?
- how much do Edelbrock/M2 heads flow out-of-the-box?
Preferably the numbers from the same flow bench. Thanks.
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544059
12/04/09 07:05 AM
12/04/09 07:05 AM
i know which cam it is, and no, mine wouldn't be better since i wouldn't even offer one.
since i don't advocate any flat tappet cam with a lobe that big, the answer would be very little.
what i can tell you is that i've pulled a large number of those "max effort" flat tappet cams out of hemi's (and wedges) that ended up with a lobe lift of around ZERO.
they sure do make a mess when that happens. obviously not all flat tappet cams fail, (and i hope yours doesn't) but when they do, it sure does make a mess. the added expense of a tear down, cleaning and rebuild is quite costly.
okay
most guys won't give out the timing events until you pay for the cam. there's a good reason for that. if your plan is to run 87 octane and make 650HP, good luck with your plan.
sorry to get off the main subject guys. i'll get out of the way now. please continue.
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544060
12/04/09 08:27 AM
12/04/09 08:27 AM
s e mich
ro23car Offline
ro23car  Offline
s e mich
Dont forget about the newer MP/Edelbrock castings
These things flow a ton, and are the best thing out there for a hemi head that is a true SR type deal..stock valve angles, and port locations..
Modern cylinder Ported mine and got 460cfm from them.. The SR Stage V's wont flow that
I have all kinds of pics, and flow sheets..PM m if your interested I will email them too you.
i beg to differ i have a set from jeff that are in the same range as yours
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544061
12/04/09 12:20 PM
12/04/09 12:20 PM
AndyF Offline
AndyF  Offline
I like the new MP/Eddy heads as well. My fault for not mentioning them in the original reply up top. Everything I've heard about them has been good. Unfortunately, MP messed up the first heads and gave their brand a black eye so now it is tough to dig out of that hole.
I have a Hemi project on the back burner and when I buy heads for it they'll probably be the MP/Eddy heads.
Re: Indy Legend or Stage 5? [Re: AndyF] #544062
12/04/09 02:00 PM
12/04/09 02:00 PM
Southington Ct.
turbobitt Online content
turbobitt  Online Content
Southington Ct.
I have a set of CNC ported Indy Legend heads. I have a solid street roller and 11:1 compression with single 1150 dominator. I am very happy with the overall performance of the engine and like a lot of the features of the Indy head. The only problem with the Indy heads is that you need to use all of Indy's stuff. Dram said to me once that if you use Indy's heads than your married to them for life. Well that makes a lot of sense since its true. If your not all that concerned about stock appearing then there OK. Indy's heads are much taller than a stage 5 head and also require there valve covers and spark plug tubes. Defbob let me borrow a set of stock valve covers and they look like they will fit but never actually ran it with a set to confirm. Headers are different and as stated in a post before, the chambers are slightly different.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Indy Legend or Stage 5? [Re: turbobitt] #544063
12/04/09 02:56 PM
12/04/09 02:56 PM
detroit area
moderncylinder Offline
detroit area
i have a set of stage v heads here that fho hand ported, 2.300 valve on the intake flowed
.1- 74
.2- 147
.3- 221
.4- 300
.5- 371
.6- 410
.7- 430
.8- 446
.9- 455
intake valve was beat up though,, might have hurt some cfm
Re: Indy Legend or Stage 5? [Re: moderncylinder] #544064
12/04/09 05:15 PM
12/04/09 05:15 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
MP,Indy,and Stage V in the hands of a good head man will perform well.
Re: Indy Legend or Stage 5? [Re: B G Racing] #544065
12/04/09 06:41 PM
12/04/09 06:41 PM
CHI-TOWN
REHBERGERRACING Offline
Redenbacher Racing
Redenbacher Racing
CHI-TOWN
Are you guys going to race your pieces of paper? No one mentions E.T. or mph. Just flow #'s. Big deal!
Page 2 of 3 1 2 3
