Page 1 of 3 1 2 3
Indy Legend or Stage 5? #544026
12/03/09 04:08 PM
12/03/09 04:08 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
Is there any advantage to either of these heads besides not having to talk to indy themselves lol. I know the indy s are a cast in stand and the 5s use stands so cost wise they are pretty similiar. Currently leaning towards the indys but would prefer to buy from a dealer on here so if any read this your input would be appreciated, Thanks
Re: Indy Legend or Stage 5? [Re: nitrousr] #544027
12/03/09 04:19 PM
12/03/09 04:19 PM
AndyF Offline
AndyF  Offline
I'd recommend talking to Tim at For Hemis Only in the Toronto area. He builds a ton of Hemi motors and will be able to give you the scoop. I'm pretty sure he'll recommend the Stage V heads but it probably depends on your requirements.
Re: Indy Legend or Stage 5? [Re: AndyF] #544028
12/03/09 05:15 PM
12/03/09 05:15 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
For my money, the Stage V is the best conventional Hemi head and the Millenium is probably the best for N/A applications.
Re: Indy Legend or Stage 5? [Re: AndyF] #544029
12/03/09 05:19 PM
12/03/09 05:19 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Dont forget about the newer MP/Edelbrock castings
These things flow a ton, and are the best thing out there for a hemi head that is a true SR type deal..stock valve angles, and port locations..
Modern cylinder Ported mine and got 460cfm from them.. The SR Stage V's wont flow that
I have all kinds of pics, and flow sheets..PM m if your interested I will email them too you.
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544030
12/03/09 05:47 PM
12/03/09 05:47 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Don't be so sure the sr stage v's wont flow that.
My FHO CNC'd stage v's flow that
Contact Tim and he'll steer you in the right direction.
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544031
12/03/09 06:11 PM
12/03/09 06:11 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Here is the flow data of my Modern Cylinder CNC Stage V standard port, standard valve heads:
"i was shocked by these numbers on the intake just as much as anyone looking at this,, this thing was wayyy good for a 2.250 valve.
superflow 600, 4.320 with bore notch, 28"
intake 2.250
.100-78.5 cfm
.200-162.4
.300-257.5
.400-342.4
.500-396.5
.600-422.4
.700-440.7
.800-450.6
.900-456.5
exhaust 1.940
open at flange/2.0" tube
.100-69.0/70.5
.200-146.2/152.4
.300-178.2/185.0
.400-208.4/220.8
.500-239.5/255.6
.600-259.1/274.0
.700-268.7/286.7
.800-273.7/293.6
.900-278.7/297.3
this is a std low exh port and a std int opening, its a good sized port but with only two pushrod tubes in the head, #1 and #5 exhaust. ferrea valves.
-Jeff"
Re: Indy Legend or Stage 5? [Re: The Shadow] #544032
12/03/09 06:14 PM
12/03/09 06:14 PM
INDY LEGENDS here mine CNC'd flow 456.
i picked up .35 over Mopar performance heads
went from 10 teens to 9.78 with a pump gas motor and indy dual 4 offset crossram.
don't go through indy direct.
Re: Indy Legend or Stage 5? #544033
12/03/09 06:44 PM
12/03/09 06:44 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
from For Hemis Only web ite. This is with a 2.30 intake Valve
FHO CNC Ported Stage V Replacement Heads. For mild to wild street strip engines.
This is the standard aluminum head used on all FHO hemi crate engines.
Exhaust Port with 1.90" Valve
Intake Port with 2.30" Valve
Flowed at 28" without tube.
Flowed at 28"
.100" 61 .100" 75
.200" 135 .200" 159
.300" 187 .300" 248
.400" 230 .400" 315
.500" 258 .500" 384
.550" 267 .550" 412
.600" 279 .600" 435
.650" 287 .650" 453
.700" 295 .700" 467
.750" 298 .750" 469
.800" 301 .800" 471
And the Good news is, You can actually talk to Tim
and he will call you back and he will return your emails
Re: Indy Legend or Stage 5? [Re: Defbob] #544034
12/03/09 06:45 PM
12/03/09 06:45 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Never said they wouldnt flow...I will stick to what i say on the edelbrocks....Here is some flow numbers beside each other...same bench also.
Defbob's compared to Mp Edelbrocks.
intake 2.250
DefBob's --- Edelbrocks
.100-78.5 cfm --- 78.6
.200-162.4 --- 165
.300-257.5 --- 253
.400-342.4 --- 333
.500-396.5 --- 395
.600-422.4 --- 431
.700-440.7 --- 450
.800-450.6 --- 459
.900-456.5
exhaust 1.940
Stage V--- --- MP edelbrocks
.100-69.0/70.5 --- 65/67
.200-146.2/152.4 --- 136/144
.300-178.2/185.0 --- 197/205
.400-208.4/220.8 --- 218/238
.500-239.5/255.6 --- 261/276
.600-259.1/274.0 --- 261/282
.700-268.7/286.7 --- 262/282
.800-273.7/293.6 --- 262/282
.900-278.7/297.3
I wasnt really trying to run down anyones head, just trying to make a point. These heads are a great casting, much better than the older MP problems with common quality control trouble.
I also know that these were flowed on the same bench and probably same operator also. So IMO they are a decent comparo.
Looks like they are a hair better than the Stage V's, probably NOT worth a small measurable amount of power...maybe..
These also have stock valve sizes. port locations, valve angles etc.
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544035
12/03/09 07:01 PM
12/03/09 07:01 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
intake 2.250
.200-162.4 --- 165
.300-257.5 --- 253
.400-342.4 --- 333
.500-396.5 --- 395
.600-422.4 --- 431
.700-440.7 --- 450
.800-450.6 --- 459
.900-456.5
exhaust 1.940
.900-278.7/297.3
Uhhh.. yes you did
Re: Indy Legend or Stage 5? [Re: The Shadow] #544036
12/03/09 07:06 PM
12/03/09 07:06 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Uhhh.. yes you did
These didnt did they so whats your point?
Re: Indy Legend or Stage 5? [Re: nitrousr] #544037
12/03/09 07:14 PM
12/03/09 07:14 PM
wappinger falls new york
Jimi_Vignogna Offline
stay away from the indy hemi heads, i made that mistake! the combustion chambers are not conventional hemi combustion chamber shape. plus indy cylinder head refuses to be accountable for there mistakes! russ and crew are just a little above everone else on this earth............
Re: Indy Legend or Stage 5? [Re: Jimi_Vignogna] #544038
12/03/09 07:24 PM
12/03/09 07:24 PM
CHI-TOWN
REHBERGERRACING Offline
Redenbacher Racing
Redenbacher Racing
CHI-TOWN
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544039
12/03/09 07:44 PM
12/03/09 07:44 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
My point is that stage v SR replacement will flow as good or better in stock configuration than edelbrock/mopar.
You stated they will not and that's just not true.
Re: Indy Legend or Stage 5? [Re: The Shadow] #544040
12/03/09 08:11 PM
12/03/09 08:11 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
hmm really..
looks to me like there down 10+cfm in the upper lift range in this particular case doesnt it..
I know what your saying...I see people recommend Stage V's all the time..im sure they are a good head. I know some people have had trouble with the older MP heads...
I spoke with a known SS/AH engine builder/racer before i was buying hemi heads, IIRC I hate putting words in any ones mouth but the guy liked the Edelbrocks, and most of the SS guys run the cast iron version (not that these ports even comes close to the stock ones lol)..In a nut shell he liked the new MP castings pretty well.
Again I wasnt trying to run down or talk bad about his, or there heads etc..just saying that Ma Mopar has some nice heads out that are just as good flowing...and guess what over $500 cheaper assembled....
I got mine through WestOaks delivered for $2300 assembled.
I have $3000 in these heads complete with CNC porting..End of the year port deal for $750, and I sold the supplied springs and retainers for like $150, and upgraded to 10 deg stuff etc.
These are also duel plug ready.
OK I give..lol you win
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544041
12/03/09 08:51 PM
12/03/09 08:51 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I wasn't quoting defbobs heads. His heads aren't SR stage v's
I guess you didn't see the post of numbers copied from the FHO website.
Flowed at 28"
.100" 61 .100" 75
.200" 135 .200" 159
.300" 187 .300" 248
.400" 230 .400" 315
.500" 258 .500" 384
.550" 267 .550" 412
.600" 279 .600" 435
.650" 287 .650" 453
.700" 295 .700" 467
.750" 298 .750" 469
.800" 301 .800" 471
It's not a pi$$ing match on who is right. Just trying to have a conversation on hemi heads
Your blanket statement on stage v's IMO is not correct.
I'm glad you happy with your edelbrocks.
I'm happy with my stage v's.
Re: Indy Legend or Stage 5? [Re: The Shadow] #544042
12/03/09 09:03 PM
12/03/09 09:03 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Flowed at 28"
.100" 61 .100" 75
.200" 135 .200" 159
.300" 187 .300" 248
.400" 230 .400" 315
.500" 258 .500" 384
.550" 267 .550" 412
.600" 279 .600" 435
.650" 287 .650" 453
.700" 295 .700" 467
.750" 298 .750" 469
.800" 301 .800" 471
Due noted..
Those flow bench numbers compared to my numbers doesnt mean squat.
million dollar question is what would my heads flow in FHO bench?
See our heads were on the same bench, thats a much better comparison, why try to compare two heads from two benches, thats why i was looking at his heads...
Re: Indy Legend or Stage 5? [Re: nitrousr] #544043
12/03/09 10:31 PM
12/03/09 10:31 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Welcome everyone to the 2009 HEMI world final flow bench races... in the far lane, the CNC MP hemi head, in the near lane the SR Stage V replacement head... and the tree drops You can take any of the heads mentioned and make a nice stout street or race hemi package. Then you can dyno it and start racing dynos
Re: Indy Legend or Stage 5? [Re: CRE2004] #544044
12/03/09 10:44 PM
12/03/09 10:44 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
WOW
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Indy Legend or Stage 5? [Re: Bob_Coomer] #544045
12/03/09 11:00 PM
12/03/09 11:00 PM
just out of curiosity, a question for those of you building your combos's with the heads mentioned. how big is the cam your running and at what compression ratio?
Page 1 of 3 1 2 3
