Re: Indy Legend or Stage 5?
[Re: AndyF]
#544029
12/03/09 05:19 PM
12/03/09 05:19 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Dont forget about the newer MP/Edelbrock castings These things flow a ton, and are the best thing out there for a hemi head that is a true SR type deal..stock valve angles, and port locations.. Modern cylinder Ported mine and got 460cfm from them.. The SR Stage V's wont flow that I have all kinds of pics, and flow sheets..PM m if your interested I will email them too you.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#544030
12/03/09 05:47 PM
12/03/09 05:47 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Don't be so sure the sr stage v's wont flow that. My FHO CNC'd stage v's flow that Contact Tim and he'll steer you in the right direction.
[Re: Bob_Coomer]
#544031
12/03/09 06:11 PM
12/03/09 06:11 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Here is the flow data of my Modern Cylinder CNC Stage V standard port, standard valve heads:
"i was shocked by these numbers on the intake just as much as anyone looking at this,, this thing was wayyy good for a 2.250 valve.
superflow 600, 4.320 with bore notch, 28"
intake 2.250 .100-78.5 cfm .200-162.4 .300-257.5 .400-342.4 .500-396.5 .600-422.4 .700-440.7 .800-450.6 .900-456.5
exhaust 1.940 open at flange/2.0" tube .100-69.0/70.5 .200-146.2/152.4 .300-178.2/185.0 .400-208.4/220.8 .500-239.5/255.6 .600-259.1/274.0 .700-268.7/286.7 .800-273.7/293.6 .900-278.7/297.3
this is a std low exh port and a std int opening, its a good sized port but with only two pushrod tubes in the head, #1 and #5 exhaust. ferrea valves.
-Jeff"
[Re: The Shadow]
#544032
12/03/09 06:14 PM
12/03/09 06:14 PM
INDY LEGENDS here mine CNC'd flow 456. i picked up .35 over Mopar performance heads went from 10 teens to 9.78 with a pump gas motor and indy dual 4 offset crossram. don't go through indy direct.
#544033
12/03/09 06:44 PM
12/03/09 06:44 PM
Posts: 2,521 Richmond Va, KeislerTKO 60...
VanishPt
from For Hemis Only web ite. This is with a 2.30 intake Valve FHO CNC Ported Stage V Replacement Heads. For mild to wild street strip engines. This is the standard aluminum head used on all FHO hemi crate engines. Exhaust Port with 1.90" Valve Intake Port with 2.30" Valve Flowed at 28" without tube. Flowed at 28" .100" 61 .100" 75 .200" 135 .200" 159 .300" 187 .300" 248 .400" 230 .400" 315 .500" 258 .500" 384 .550" 267 .550" 412 .600" 279 .600" 435 .650" 287 .650" 453 .700" 295 .700" 467 .750" 298 .750" 469 .800" 301 .800" 471 And the Good news is, You can actually talk to Tim and he will call you back and he will return your emails
[Re: Bob_Coomer]
#544035
12/03/09 07:01 PM
12/03/09 07:01 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Never said they wouldnt flow...I will stick to what i say on the edelbrocks....Here is some flow numbers beside each other...same bench also.
Defbob's compared to Mp Edelbrocks. intake 2.250
DefBob's --- Edelbrocks .100-78.5 cfm --- 78.6 .200-162.4 --- 165 .300-257.5 --- 253 .400-342.4 --- 333 .500-396.5 --- 395 .600-422.4 --- 431 .700-440.7 --- 450 .800-450.6 --- 459 .900-456.5
exhaust 1.940 open at flange/2.0" tube Stage V--- --- MP edelbrocks .100-69.0/70.5 --- 65/67 .200-146.2/152.4 --- 136/144 .300-178.2/185.0 --- 197/205 .400-208.4/220.8 --- 218/238 .500-239.5/255.6 --- 261/276 .600-259.1/274.0 --- 261/282 .700-268.7/286.7 --- 262/282 .800-273.7/293.6 --- 262/282 .900-278.7/297.3
I wasnt really trying to run down anyones head, just trying to make a point. These heads are a great casting, much better than the older MP problems with common quality control trouble.
I also know that these were flowed on the same bench and probably same operator also. So IMO they are a decent comparo. Looks like they are a hair better than the Stage V's, probably NOT worth a small measurable amount of power...maybe..
These also have stock valve sizes. port locations, valve angles etc.
Uhhh.. yes you did Modern cylinder Ported mine and got 460cfm from them.. The SR Stage V's wont flow that
[Re: Bob_Coomer]
#544041
12/03/09 08:51 PM
12/03/09 08:51 PM
Posts: 2,175 Duloc
The Shadow
Duloc
I wasn't quoting defbobs heads. His heads aren't SR stage v's I guess you didn't see the post of numbers copied from the FHO website. FHO CNC Ported Stage V Replacement Heads. For mild to wild street strip engines. This is the standard aluminum head used on all FHO hemi crate engines. Exhaust Port with 1.90" Valve Intake Port with 2.30" Valve Flowed at 28" without tube. Flowed at 28" .100" 61 .100" 75 .200" 135 .200" 159 .300" 187 .300" 248 .400" 230 .400" 315 .500" 258 .500" 384 .550" 267 .550" 412 .600" 279 .600" 435 .650" 287 .650" 453 .700" 295 .700" 467 .750" 298 .750" 469 .800" 301 .800" 471 It's not a pi$$ing match on who is right. Just trying to have a conversation on hemi heads Your blanket statement on stage v's IMO is not correct. I'm glad you happy with your edelbrocks. I'm happy with my stage v's.
[Re: Bob_Coomer]
#544045
12/03/09 11:00 PM
12/03/09 11:00 PM
just out of curiosity, a question for those of you building your combos's with the heads mentioned. how big is the cam your running and at what compression ratio?
