Spark Plugs for edlebrock preformer heads #543425
12/02/09 08:16 PM
12/02/09 08:16 PM
Aubrey, Texas
O
oldtimer5151 Offline OP
O
Aubrey, Texas
I need some advice for some spark plugs for my edlebrock heads. They haven`t been ported. I have about 12.5 to 1 with the 84cc chambers. Thanks
Re: Spark Plugs for edlebrock preformer heads [Re: oldtimer5151] #543426
12/02/09 09:56 PM
12/02/09 09:56 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I am using Autolite 3924. There are many threads on sparkplugs for those heads, see the google search button at the top.
Re: Spark Plugs for edlebrock preformer heads [Re: oldtimer5151] #543427
12/02/09 10:39 PM
12/02/09 10:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Says right in your head box instructions what Champions to use!!
Re: Spark Plugs for edlebrock preformer heads [Re: Exit1965] #543428
12/02/09 11:06 PM
12/02/09 11:06 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Same plugs I use.
Re: Spark Plugs for edlebrock preformer heads [Re: oldtimer5151] #543429
12/03/09 12:36 AM
12/03/09 12:36 AM
ill
dennismopar73 Offline
ill
the plugs that you run will be diffrent on that
dome piston that that of the flat top
you can hit the piston on the dome
i run NGK race plug (have to get the number )
but i run alcohol so wont help you much
Re: Spark Plugs for edlebrock preformer heads [Re: oldtimer5151] #543430
12/03/09 01:04 PM
12/03/09 01:04 PM
Aubrey, Texas
O
O
Aubrey, Texas
I cross referenced the 3924 auto. and bought some NGK`s, because they were on sale for $1.99. Edelbrock recommends the rc12yc and I have used the 9yc champions. The 12 require a fatter jet. The 9`s are too cold. The NGK`s are BKR6E. We will see. Thanks
Re: Spark Plugs for edlebrock preformer heads [Re: dennismopar73] #543431
12/03/09 01:10 PM
12/03/09 01:10 PM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
I ran into that with mine. Builder mistake,(ME). I should have mocked it up then massaged the pistons...but it was all together. I now run the Champion C59R plug.
Re: Spark Plugs for edlebrock preformer heads [Re: oldtimer5151] #543432
12/03/09 01:53 PM
12/03/09 01:53 PM
I have ran the Champion RC12YC and the RC9YC as well as the AR3911 and 3910 in my Eddy headed pump gas 518 C.I. street motor(10.29to 1 comp. ratio, the RC9YC and the 3911 work fine, not to hot(the way I read plugs anyways with 34 to 36 degrees timing ) and not to cold )
Re: Spark Plugs for edlebrock preformer heads [Re: Cab_Burge] #543433
12/04/09 01:09 AM
12/04/09 01:09 AM
ill
ill
NGK is making some serious plugs right now
we use to joke about them 'motorcyle plug' in race car but it's diffrent
they are really nice plug
almost all chebbys have had ngk since 1999
(A C DELCO doesn't make plugs, oo they don't make anything )just a name on box
same guy invented ACDELCO made Champion mmm
Motorcraft/Autolite same co.
