Just measure your original one and call or email the sellers for their specs. The earlier ones were made of fiberglass and are easily repairable, the later ones, and the aftermarket ones are plastic. The original plastic ones were prone to cracking on the top near the rear end piece. You can also (maybe) find a rear cap that has the grooves open so that you can have a rear seat floor light and it has a built in cigarette lighter in the center. they are pretty cool. I'm going to mount LED lights behind it for floorwell lighting. If nothing else, it is a factory piece that allows you to have a 12 volt power supply. You might be a lot better off repairing the console you have. I looked at this issue before I bought one for my Coronet floor shift conversion. I bought an original fiberglass one. Now, I think I'm just going to make a custom one out aluminum, but incorporate the factory end piece and other trim pieces.
