Got my ported heads back today...is this okay??? #542611
12/01/09 11:54 PM
12/01/09 11:54 PM
Escondido, CA
64physhy Offline OP
64physhy  Offline OP
Escondido, CA
I just got my heads back from being ported today. I won't say who did it until I get to talk to them first. They are magnum heads, fully ported. They broke through where the valve cover bolt holes are. In one port, the hole is about 3/16" X 1/8", and the rest are pinholes with paper thin metal left. I don't know much about porting heads. I know definitely do not break into any of the water journals, which they did not. Is this normal, or should I be getting in someones a$$ over it? I'll try to get pics up later. Thanks, Dave
Re: Got my ported heads back today...is this okay??? [Re: 64physhy] #542612
12/01/09 11:57 PM
12/01/09 11:57 PM
detroit area
moderncylinder Offline
detroit area
normal
Re: Got my ported heads back today...is this okay??? [Re: 64physhy] #542613
12/02/09 12:00 AM
12/02/09 12:00 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I break through the rocker cover bolt holes on every OEM SB head I do.
It doesnt hurt anything. I just use RTV on a stud.
Re: Got my ported heads back today...is this okay??? [Re: moderncylinder] #542614
12/02/09 12:01 AM
12/02/09 12:01 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
Yes that is common,you can JB weld the surface if you want but when the bolts are in place it will not be leaking
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Got my ported heads back today...is this okay??? [Re: 77DragracerR/T] #542615
12/02/09 12:08 AM
12/02/09 12:08 AM
Escondido, CA
64physhy Offline OP
64physhy  Offline OP
Escondido, CA
Thanks, guys. I was worried at first, then thought it didn't seem like it would hurt, but wanted to make sure. Thanks again
Re: Got my ported heads back today...is this okay??? [Re: 64physhy] #542616
12/02/09 12:47 AM
12/02/09 12:47 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Shoot, I break through there, the rocker stud hole, the head bolt hole and, if the head has the material, through the pushrod hole. Sleeves for the bolt hole and the pushrod hole, thread sealer on the other two.
Re: Got my ported heads back today...is this okay??? [Re: dodgeboy11] #542617
12/02/09 12:49 AM
12/02/09 12:49 AM
Escondido, CA
64physhy Offline OP
64physhy  Offline OP
Escondido, CA
So then, on the ones where there are a couple pinholes and the metal is thinner than paper, should just go ahead and knock out that thin piece to prevent it from possibly being sucked in?
Re: Got my ported heads back today...is this okay??? [Re: 64physhy] #542618
12/02/09 01:19 AM
12/02/09 01:19 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
If it's secure, I wouldn't worry about it, but if it's flapping in the wind, definitely knock it out so it can't come loose and run through the motor.
