differance between auto and std. carbs #542454
12/01/09 09:38 PM
12/01/09 09:38 PM
car48nut Offline OP
car48nut  Offline OP
I need to know the differance between the auto and std. shift carbs. I have a 44289 carb for a 440 auto. Can it be built as a 4426s carb? What is the differance? Will it work with a 4spd. trans? Thanks
Re: differance between auto and std. carbs [Re: car48nut] #542455
12/01/09 09:42 PM
12/01/09 09:42 PM
scratchnfotraction Offline
thottle stud will not have the longer stud part for the auto kickdown linkage
dont see why you cant use either one
Re: differance between auto and std. carbs [Re: car48nut] #542456
12/01/09 10:01 PM
12/01/09 10:01 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
the calibration is a little different , most people would never know the difference , rebuild it if it needs it and use it .
Re: differance between auto and std. carbs [Re: JohnRR] #542457
12/02/09 12:38 AM
12/02/09 12:38 AM
car48nut Offline OP
car48nut  Offline OP
So I will not have any tuning problems, right? thanks
Re: differance between auto and std. carbs [Re: car48nut] #542458
12/02/09 06:08 AM
12/02/09 06:08 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
No more than the difference between 2 brands of gas!
You have probably changed something from factory stock or even the differene between the gas available back then compared to now warrants calibration of the carb with a good A/F meter.
