Page 13 of 16 1 2 11 12 13 14 15 16
Re: Dakota spindles on 73 clubcab done (almost) [Re: 85_Ram_4speed] #54244
09/30/08 09:19 AM
09/30/08 09:19 AM
Clinton Twp. Michigan
coronet1966d Offline
my truck was axle flipped when i bought it and that was about a 5" drop but the shocks were binding and hitting my exhaust
Re: Dakota spindles on 73 clubcab done (almost) [Re: coronet1966d] #54245
09/30/08 08:47 PM
09/30/08 08:47 PM
Sunnyvale, CA.
3XCHARM Offline
3XCHARM  Offline
Sunnyvale, CA.
An axle flip alone will drop the rear the thickness of the axle plus the thickness of the spring pack. Since you are now gonna have the axle on top of the springs.
A longer shackle alone will drop the rear only HALF the difference of the stock shackle versus the longer shackle. A 4" longer shackle by itself will only drop the rear 2" since you are only dropping one end of the spring pack.
If you have a 4" longer shackle AND a 4" dropped front spring hanger then you would get 4" drop in the rear.
1975 Ramcharger 6" lift 35" Mud Terrains 8 lug 44 front, 60 rear. (R.I.P.)
1976 D100 lowered 3" & 5" Now with a 440!!! (sold)
On the hunt for another beauty to build.
Re: Dakota spindles on 73 clubcab done (almost) [Re: 3XCHARM] #54246
09/30/08 09:48 PM
09/30/08 09:48 PM
NJ
z1bigtom Offline
z1bigtom  Offline
NJ
I'm sure everyone saw my shackles i made, well tommorow my rear spring front hangers should be done also...This will raise the front of the rear spring 4" from stock location along with a 4" longer shackle 4" drop in rear....FREE!!!
78 D200 Clubcab, 400, 727, Dana 60 welded...Droped 3" front..Rear soon to come
Re: Dakota spindles on 73 clubcab done (almost) [Re: z1bigtom] #54247
06/27/09 09:40 AM
06/27/09 09:40 AM
scratchnfotraction Offline
great reading
I will save this for sure
thanks for the link to it
Re: Dakota spindles on 73 clubcab done. [Re: ramblebee] #54248
07/26/09 10:15 PM
07/26/09 10:15 PM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
Are the chassis tech spindles still availble on ebay, I can't seem to find them. And am I the only person that thinks $735 seems a bit high for a set of pocketed control arms? Maybe I'm missing something, but they don't look that hard to make. Should be able to modifiy a stock pair easy enough.
Re: Dakota spindles on 73 clubcab done. [Re: cantspel] #54249
07/26/09 10:29 PM
07/26/09 10:29 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I lucked out big time on mine thanks to a member that I got them from. Yes Anything over $300 is high to me for them. Havent put them on anything yet and would like to run the Dakota sp and See where it sits Modifiing your stack ones will prove tuff IMO but you could make a Jig to build some from your stock ones
Re: Dakota spindles on 73 clubcab done. [Re: ramblebee] #54250
07/26/09 11:08 PM
07/26/09 11:08 PM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
have the spindles disappeared?
Re: Dakota spindles on 73 clubcab done. [Re: cantspel] #54251
07/26/09 11:14 PM
07/26/09 11:14 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Summit sells belltechs for $300 so Jegs will have the same. Do a web search theres another company that makes them
Re: Dakota spindles on 73 clubcab done. [Re: 76dodgeboy] #54252
08/24/09 10:27 AM
08/24/09 10:27 AM
Perryopolis PA
turbododgepirate Offline
Perryopolis PA
UPDATE on my 1985 Dodge D100 pickup.
Okay, did the front this weekend and ran into a few things.
Parts: 1996 Dakota drop spindles, 2" drop springs from Mid america customs, tie rod adjusting sleeves from a C body Moog part #ES440S 76 Newyorker adjusting sleeves.
Okay, I haven't read back through the posts so I'll cover what I ran into on my truck. 1)the brake caliper brackets had to be ground down about 1/8" to fit on the dakota spindles (I think this has been mentioned), the brake lines had to be bent to clear the nuts on the spindle, I know that has been mentioned. The Adjusting sleeves I ordered were shorter than the stock ones. I need about 1" longer than stock. I think Napa may have screwed up. Anybody have a measured length on the 76 new yorker sleeves? I'll try to get pics soon.
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54253
08/24/09 02:10 PM
08/24/09 02:10 PM
Perryopolis PA
Perryopolis PA
85 Ram 4 Speed post got me to wondering.So I did a little research.It looks like there was a tie rod change,both inner and outer in 79.According to my parts book( which I just noticed only goes up to 90) 72-78 inner and outer tie rods are 7.44" long.In 79 both inner and outer tie rods went to 5.16" long.Also the stud got larger in 79.But this shouldnt dicourage anyone,its just a matter of finding the correct tie rod and sleeve combo.This book is a awesome tool. If anyone needs help finding the right parts let me know.Or just go look it up at your local parts store.
Ahhhhh Looks like this might be my issue here. A 1985 truck, I guess I have the 5.16" long inner and outer tie rod ends. So I need to find 7.44 inch inner and outer tie rods that will work on my 85. Possibly just a 7.44 inch inner, that would give me about 1.5" inside the adjusting sleeve on both the inner and outer tie rod ends. Is that enough? Anyone know if a 77 inner tie rod will fit where a 85 inner tie rod was?
Re: Dakota spindles on 73 clubcab done (almost) [Re: turbododgepirate] #54254
08/31/09 11:18 AM
08/31/09 11:18 AM
Perryopolis PA
Perryopolis PA
Okay, On a 1985 Dodge D100 with 2" drop springs and 96 dakota spindles(?) that the tie rod end comes in from the bottom the suspension geometry is off. I would be better off with the tie rod end coming in from the top, that would be perfect. Does anybody know what the angle of the ream I can use to do this?
Re: Dakota spindles on 73 clubcab done (almost) [Re: turbododgepirate] #54255
09/02/09 04:16 PM
09/02/09 04:16 PM
Perryopolis PA
Perryopolis PA
A picture of the suspension with a 96 dakota drop spindle and 2" lowering springs from Mid America Customs. We are going to relocate the outer tie rod end to the top of the spindle arm for better suspension geometry.
Re: Dakota spindles on 73 clubcab done (almost) [Re: turbododgepirate] #54256
09/02/09 04:40 PM
09/02/09 04:40 PM
Perryopolis PA
Perryopolis PA
A picture from the side. I have some lower profile tires for the front to make it more even.
Re: Dakota spindles on 73 clubcab done (almost) [Re: turbododgepirate] #54257
09/02/09 10:23 PM
09/02/09 10:23 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
What size is on it now. What is the distance from the center of the hub to the bottom of the wheel lip?
Re: Dakota spindles on 73 clubcab done (almost) [Re: 76dodgeboy] #54258
09/03/09 03:53 AM
09/03/09 03:53 AM
Perryopolis PA
Perryopolis PA
The rears are 255/60-15 the fronts are whatever the stock 15" tire is. I'll measure the distance for you.
Re: Dakota spindles on 73 clubcab done (almost) [Re: turbododgepirate] #54259
09/03/09 01:45 PM
09/03/09 01:45 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
My old 73 Clubcab Was 13" from hub to wheel lip and it road on the bumpstop brackets. Cut 1.5 coils and I ran 205/75r15 on it. Never got the chance to chorten the bumpstops before the motor blew. My buddy has it now but will be putting coils from a 85 2wd rc in it. I have some pocketed control arms and want to use the drop coil and spindles. I want my truck LOW
Re: Dakota spindles on 73 clubcab done (almost) [Re: coronet1966d] #54260
09/04/09 10:24 AM
09/04/09 10:24 AM
Jasper Indiana
BIGMIKE@RIDETECH Offline
Jasper Indiana
Awesome work! Im going to start collecting parts tonight for my 76 D200. Ill be incorporating them into my existing airride suspension. Has anyone went low enough that they have had to pie cut the upper control arm and roll the upper ball joint for better angle?
Re: Dakota spindles on 73 clubcab done (almost) [Re: BIGMIKE@RIDETECH] #54261
09/04/09 10:34 AM
09/04/09 10:34 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I dont believe anyone has and I want to get one of mine as low as possible. Ive considered moving the upper control arm upwards but than the steering is in the way. Also my idler arm was very close to the strutrod witch would just need moved up also. I need to find another clubcab. They look good slammed. SWEET TRUCK btw
Re: Dakota spindles on 73 clubcab done (almost) [Re: turbododgepirate] #54262
09/04/09 10:36 AM
09/04/09 10:36 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Whats stock? They had several tire sizes for stock I had an Rc that called for 195 or 205s cant remember and they also came with 31s
Re: Dakota spindles on 73 clubcab done (almost) [Re: 76dodgeboy] #54263
09/04/09 11:35 AM
09/04/09 11:35 AM
Perryopolis PA
Perryopolis PA
225/75-15 was stock.
