P0740 and P0700 codes in a 99 Grand Voyager. #541985
12/01/09 02:41 PM
12/01/09 02:41 PM
IMGTX Offline OP
IMGTX  Offline OP
I have a friend that is getting a P0740 and P0700 codes from his ECM.
p0740=torque converter clutch control circuit
p0700=internal trans controller
I haven't pulled the codes directly from the TCM but is there any advice on what to look for or might be common on these vans?
I would love to think I it would be as simple as a new lockup solenoid but I am never lucky enough to have a simple to do repair unless the part is $5000 dollars.
Re: P0740 and P0700 codes in a 99 Grand Voyager. [Re: IMGTX] #541986
12/01/09 06:19 PM
12/01/09 06:19 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
trans is dying... dan
Re: P0740 and P0700 codes in a 99 Grand Voyager. [Re: ph23vo] #541987
12/01/09 06:40 PM
12/01/09 06:40 PM
IMGTX Offline OP
IMGTX  Offline OP
The trans seems to be acting fine 99.9% of the time. My concern is that I have read posts on the internet from people who had the trans rebuilt, replaced the TCM, solenoid packs, input/output speed sensors etc and none seemed to be the silver bullet to fix it. Still the problems persisted.
Obviously they had bad mechanics but I am calling on the awesome wisdom and powers of the Moparts Guru's to intercede on this cars behalf.
Re: P0740 and P0700 codes in a 99 Grand Voyager. [Re: IMGTX] #541988
12/01/09 06:51 PM
12/01/09 06:51 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
any time you get a P07XX code, the PCM will throw the P0700 code.
Get a wiring diagram and check all the wiring for the TCC, especially the connectors and in the fluid.
Re: P0740 and P0700 codes in a 99 Grand Voyager. [Re: ph23vo] #541989
12/01/09 10:05 PM
12/01/09 10:05 PM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
Well i will start off by saying I am the trans guy in a large dealer. 99% of the time when i see a P0740 TCC out of range code in a caravan, it is a converter failure. Dropping the pan and looking for coffee grinds and a big fuzzy magnet will confirm. Some people have gotten away with just a converter swap. I of course would overhaul. And at this point it should be a cheap overhaul, with just clutches and seals.
You should be able to find someone on this board in your area to hook you up at a reasonable price.
