Valve Spring Intro Needed #541728
12/01/09 05:21 AM
12/01/09 05:21 AM
scamp74 Offline OP
scamp74  Offline OP
I'm new to building engines, and one thing that I don't quite grasp yet is how to select the correct valve springs and retainers for your combo. What's the best way to do this? Spring pressures, installed heights, spring diameter, how do you pick the right ones? Thanks for the help!
Re: Valve Spring Intro Needed [Re: scamp74] #541729
12/01/09 01:46 PM
12/01/09 01:46 PM
Contact or use the springs specs. furnished from the cam company same thing on the retainers and keepers. I like to use the super seven or ten degree keepers and retainers on all of my race motors and my street and strip motors
Re: Valve Spring Intro Needed [Re: scamp74] #541730
12/01/09 02:32 PM
12/01/09 02:32 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
You need advise from a competent engine builder.
Comp Cams still lists a 928 spring for some of their SB solid cams.
Although the spring pressures are suitable, a 1.550" diameter spring
won't clear the rocker shaft WITHOUT A ROCKER ARM ON IT!
Somebody really needs to address the roller sping selection for
OEM/Edelbrock heads. (1.46"-1.48")
Re: Valve Spring Intro Needed [Re: Cab_Burge] #541731
12/04/09 08:19 AM
12/04/09 08:19 AM
scamp74 Offline OP
scamp74  Offline OP
Thanks!
Re: Valve Spring Intro Needed [Re: S/ST 3040] #541732
12/04/09 08:52 AM
12/04/09 08:52 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I thought that's what drum grinders were for, Its always nice to tear up a new set of roller rockers
