NHRA 340 engine blueprint specs. #541222
11/30/09 04:41 PM
11/30/09 04:41 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Why does the NHRA list the 1971 340 at 11.8 comp. ratio and all pre 71 340s at the factory 10.5 C.R.? Thanks.
Re: NHRA 340 engine blueprint specs. [Re: ragtop] #541223
11/30/09 08:43 PM
11/30/09 08:43 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
68-71 all show the same blueprint specs.
With 4.040" x 3.31" and 4.180" x .028" gasket, I still
come up with 11.839:1
That's not counting .013" additional stroke and
.070" allowable over bore.
It's a possible mis-print on the specs.
Re: NHRA 340 engine blueprint specs. [Re: ragtop] #541224
11/30/09 09:50 PM
11/30/09 09:50 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
those specs were provide by the factory...
also in the old days..LOL...the factory provide the cam specs which had a very long duration..so that anything less was legal.
now nhra only limited the valve lift and does not check duration.
the factory was just trying to give their team racers GOOD specs for their engines.
Tony
70 AARCuda Vitamin C
