Re: Best way to strip paint from an engine?
[Re: Neil]
#541172
11/30/09 03:35 PM
11/30/09 03:35 PM
Posts: 4,799 ILL
MLR426
ILL
Any paint stripper will work, but it might not do your gaskets any favors.
Do you have a place that dips cars near you ? dip stripper is by far the best method of removing all crud and paint from an engine.
logan426
[Re: MLR426]
#541173
11/30/09 03:42 PM
11/30/09 03:42 PM
Posts: 15,487 Florida
scratchnfotraction
I use the ez off oven cleaner and it will strip the paint,oil,grit,grim right off I then rinse and blow dry them and paint I get it at the dollor store for a buck a can and use 2-3 cans and do it a least 2x for stripping the paint down cheap and fast
