A new way for slick balancing? #539994
11/29/09 09:15 AM
11/29/09 09:15 AM
Duloc
The Shadow Offline OP
Duloc
Has anybody tried balance beads for slick balancing?
http://www.counteractbalancing.com/
Looks like an easy fix to the old debate of do you or don't you balance your slicks.
Re: A new way for slick balancing? [Re: The Shadow] #539995
11/29/09 09:22 AM
11/29/09 09:22 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I do it the easy way I don't balance them
Re: A new way for slick balancing? [Re: Quicktree] #539996
11/29/09 10:26 AM
11/29/09 10:26 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
tried both ways,no diff,
Re: A new way for slick balancing? [Re: The Shadow] #539997
11/29/09 10:29 AM
11/29/09 10:29 AM
madison, ohio
modified1090 Offline
madison, ohio
it might work if you don't run tubes.
Re: A new way for slick balancing? [Re: modified1090] #539998
11/29/09 10:52 AM
11/29/09 10:52 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
I've used this on out of balance truck tires and can tell you it definitely works in that application.
You need a shielded valve stem to keep the media from getting in the valve, and it does make a mess when you pull it apart.
I dont think I would use it on a race car slick. But thats not to say it wouldn't work.
SS/DA 1924
Re: A new way for slick balancing? [Re: Quicktree] #539999
11/29/09 01:37 PM
11/29/09 01:37 PM
Duloc
Duloc
Why would you need balanced slicks when all you do is explode pinions anyway?
I can't see why it wouldn't work in a tube when it can be injected in a valve stem.
Re: A new way for slick balancing? [Re: The Shadow] #540000
11/29/09 02:05 PM
11/29/09 02:05 PM
Q
Quicktree Offline
Quicktree  Offline
Q
no more exploding rears. O threw the 83/4s in the trash where they belong
Re: A new way for slick balancing? [Re: Quicktree] #540001
11/29/09 02:13 PM
11/29/09 02:13 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We run tubes in the Phoenix's and I quit balancing years ago.Made no difference.
Nautilus Racing-
Re: A new way for slick balancing? [Re: Chris2581] #540002
11/29/09 02:15 PM
11/29/09 02:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yep same here. I have had one set of slicks over the years that gave us a problem. a good set shouldn't need balancing.
Re: A new way for slick balancing? [Re: Quicktree] #540003
11/29/09 02:24 PM
11/29/09 02:24 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have used this in jeep tires with good luck. I currently have my spare on the front of my jeep and its got 1000 airsoft pelets in it and it works great.
I don't know how well it would work in a slick application. Since they grow and change so much during a run it might cause problems.
68 Barracuda Formula S 340
Re: A new way for slick balancing? [Re: Bad340fish] #540004
11/29/09 03:30 PM
11/29/09 03:30 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The next time any of you non-balance guys are at an event where any of the major slick manus have a truck stop and ask them if they recommend slick balancing. If you don't believe what they tell you then get some shock sensors from Racepak and look at the data you retrieve from them. See if this changes your mind.
Re: A new way for slick balancing? [Re: Quicktree] #540005
11/29/09 03:43 PM
11/29/09 03:43 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I read the great debate threads and went this way as well. No issue at all.
Re: A new way for slick balancing? [Re: BobR] #540006
11/29/09 04:20 PM
11/29/09 04:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Bob you are probably right, but at our level of bracket racing I doubt it make any difference. you make a ton more power than we do. I know for a fact it doesn't make any difference in et or 60'. we have had them balanced before and pulled the weights off. made no difference at all
Re: A new way for slick balancing? [Re: gsmopar] #540007
11/29/09 05:24 PM
11/29/09 05:24 PM
Az
Crizila Offline
Crizila  Offline
Az
There is no debate. You balance them! You guys that don't balance your slicks are part of the reason why I have to spend as much time as I do in the staging lanes - while they are sweeping your parts off the track.
Fastest 300
Re: A new way for slick balancing? [Re: Crizila] #540008
11/29/09 05:43 PM
11/29/09 05:43 PM
Locomotion Offline
Locomotion  Offline
Balance them!
Just because you don't "feel" or "notice" a difference, it doesn't mean that they are "right". Same thing applies to engine balancing. Factory specs are usually off, but it gets them by. Even if it makes .01 difference in a run, it won't be obvious because there are dozens of other variables that affect the run. But it does make a positive difference not only in ET & MPH, but in the life of related components, even if it's just a little bit. Find enough "little bits" and the difference will be obvious..
Re: A new way for slick balancing? [Re: Locomotion] #540009
11/29/09 06:53 PM
11/29/09 06:53 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I quit balancing years ago. Had no issues for a long time. Then I got a set of slicks that caused a noticeable shake in shutdown. Was in a pinch and wondered which tire was the problem. Called my shock manufacturer on the phone about something else and the subject came up. He said crawl under the car after making a pass and put your hand on each shock. Guess what one shock was noticeably warmer than the other. That tire was out of balance pretty bad. The other didn't hardly need any weight to zero out.
What warms the shock up? I can answer that. When a shock gets worked the fluid is forced to pass through restricters. The more it is worked the hotter the fluid becomes.
Re: A new way for slick balancing? [Re: Leon441] #540010
11/29/09 07:39 PM
11/29/09 07:39 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Exactly right. As is this.
"But it does make a positive difference not only in ET & MPH, but in the life of related components, even if it's just a little bit."
Re: A new way for slick balancing? [Re: BobR] #540011
11/29/09 10:23 PM
11/29/09 10:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
So, why do you balance the wheels/tires on your truck, but not on your race car that runs maybe 3 times as fast? You put a 4 or $500 set of tires on, but won't spend 10 or 15 bucks for balancing? Even using a bubble machine is better than nothing. I would balance the tires when new, sometimes they only take an ounce or so, sometimes quite a bit more. At about 50 or 60 runs, I take 'em off and rebalance them. Always made a difference for me.
Re: A new way for slick balancing? [Re: CMcAllister] #540012
11/29/09 11:34 PM
11/29/09 11:34 PM
Locomotion Offline
Locomotion  Offline
The "truck" reference made me realize that I should elaborate a bit. Any imbalance in the tire/wheel is dampened by the lower air pressures used in slicks! The higher the air pressure, the more obvious any imbalance will be. But bottom line is that there is normally some degree of imbalance that should be neutralized!
Re: A new way for slick balancing? [Re: Locomotion] #540013
11/30/09 12:32 AM
11/30/09 12:32 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Semi-trucks blow tires all the time, I see tire pieces on the highway every day. Where do all those beads go when that happens?
