Father-in-law purchased a aftermarket radio that meets his needs for his 1976 Warlock (D100). Only complaint that I have seen in this particular radio is a complaint of the radio not booting up when the car is started quickly. They mention the key needs to be turned on, then started. I'd like to cure this problem before installing it.
From what it sounds like it is caused by the "switched 12v" source not letting the radio start up and it locks up. I figured by piggy-backing off the ballast/coil wiring I can resolve this. Since then the radio would be powered while cranking as well. (Which I know could be a concern in dying battery situations, but the small current draw doesn't concern me. And the vehicle is well maintained.)
Problem with that is full voltage would then be fed to the coil positive versus the dropped voltage it is designed for. Anyone have diode information on what I am looking for? I understand the concept, but do not know what style/size/rating/etc I am looking for.
Any advise?
Thanks-
