Page 6 of 7 1 2 3 4 5 6 7
Re: Rust removal recipe ! works great! cheap to make!! [Re: JAMESDART] #539587
08/18/10 04:56 PM
08/18/10 04:56 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
i mixed up 5 gallons. i put in a really nasty rusty 383-4 intake that sat outside for a really long time. it came out awsome, but i didnt want to remove it until i figured out what would work to nuetralize it. it sat in the tote a few days i put some brackets in it yesterday and the stuff is dead. didnt touch the rust on the brackets. so yeah its cheap to make but, 20 bucks to derust and intake manifold, im not sure if its really worth it. evaporust seems to last longer.
Re: Rust removal recipe ! works great! cheap to make!! [Re: JAMESDART] #539588
08/18/10 07:09 PM
08/18/10 07:09 PM
CentralVA.
BBCoronet Offline
BBCoronet  Offline
CentralVA.
Soooo, Has anyone tried this stuff out on something that has an aluminum component attached?? I have some carb bases that are a little crusty and was wondering if they could be dipped to clean up the rusted parts.... Anyone have an idea
Re: Rust removal recipe ! works great! cheap to make!! [Re: BBCoronet] #539589
08/28/10 05:10 PM
08/28/10 05:10 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Here's a box I've made for trying this on a rear valance. I'll post again when it's done. I also thru in some c-clamps to take up space. I put in 9 gallons of the "juice"
Re: Rust removal recipe ! works great! cheap to make!! [Re: varunner] #539590
08/28/10 05:11 PM
08/28/10 05:11 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
lined with 2 layers of plastic
Re: Rust removal recipe ! works great! cheap to make!! [Re: varunner] #539591
08/28/10 05:11 PM
08/28/10 05:11 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
ready to fill up
Re: Rust removal recipe ! works great! cheap to make!! [Re: varunner] #539592
08/28/10 06:05 PM
08/28/10 06:05 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Looks good but your going to want to remove the paint off the valance before you dunk it...it wont remove paint.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Rust removal recipe ! works great! cheap to make!! [Re: Troy] #539593
08/28/10 06:19 PM
08/28/10 06:19 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Just trying to remove some light rust.
Re: Rust removal recipe ! works great! cheap to make!! [Re: Troy] #539594
08/29/10 02:04 PM
08/29/10 02:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you leave it in there long enough it will ...
Re: Rust removal recipe ! works great! cheap to make!! [Re: JohnRR] #539595
08/29/10 02:24 PM
08/29/10 02:24 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Evaporust , I found some last night but it was just a small bottle , is this a concentrate , it didn't say anything on the bottle so this is probably a stupid question. If it's not I'd have to spend $100 to get enough to put anything like a valve cover in it
I used it to clean up my spindles and instead of pouring a ton of evaporust into a big container I put them in a big zip lock bag one at a time and filled the excess space with small river rocks. This allowed me to use alot less of the evaporust and still get the whole spindle submerged.
For a valve cover I would settle for cleaning it one side at a time rather than using a lot of fluid to do it all at once. I'd make a rectangular frame out of scrap wood just big enough to hold the object and then set a trash bag in it filled with 1/4" or so of evaporust and then just rotate the valve cover over every few hours.
You can clean sheetmetal with this stuff by making a dam out of clay and then pour the evaporust inside. When you done you can remove it with a suction bulb.
Re: Rust removal recipe ! works great! cheap to make!! [Re: varunner] #539596
08/29/10 02:49 PM
08/29/10 02:49 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Framing square and clamps turned out pretty good. Rear valance needed to be flipped over, it'll come out tomorrow.
Re: Rust removal recipe ! works great! cheap to make!! [Re: varunner] #539597
08/29/10 02:50 PM
08/29/10 02:50 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Re: Rust removal recipe ! works great! cheap to make!! [Re: varunner] #539598
01/05/11 10:42 PM
01/05/11 10:42 PM
San Antonio, Tx
bulletpruf Offline
bulletpruf  Offline
San Antonio, Tx
I'm on my second batch. Works quite well for me. I put parts in when I get home in the evening and then pull them out the next evening after work. Garage is cold this time of year, and I don't have time after work to get the sandblaster going, so this way I'm able to a little bit during the week.
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Rust removal recipe ! works great! cheap to make!! [Re: varunner] #539599
01/06/11 10:29 AM
01/06/11 10:29 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
ready to fill up...
I would have just gone to Toys R Us and be done with it.
Re: Rust removal recipe ! works great! cheap to make!! [Re: Commando1] #539600
01/06/11 06:01 PM
01/06/11 06:01 PM
indiana
generallee6901 Offline
indiana
I have also used this with great results.I mixed one gallon first to try than mixed 5 gallons and as i took parts out that were ready i added more parts to see how long it would last.I ended up using that 5 gallons for three weeks and cleaned a lot of parts.I put it in a plastic tote with a lid.Was nice and warm out then.Have not tryed it in the cold.
Re: Rust removal recipe ! works great! cheap to make!! [Re: varunner] #539601
01/07/11 02:33 PM
01/07/11 02:33 PM
Northeast
edl Offline
edl  Offline
Northeast
Re: Rust removal recipe ! works great! cheap to make!! [Re: generallee6901] #539602
01/09/11 10:59 PM
01/09/11 10:59 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Glad to find this thread is still active and it's great to see what you all are doing with it. I was reminded of it just recently:
My 7-year-old found this same mixture in a paperback science book for kids showing them how to turn tarnished pennies all shiny.
It explains that the acetic acid in vinegar changes into hydrochloric acid when it mixes with the salt. Same as stomach acid. No mention of the lemon juice.
He drops a penny in and 10 seconds later it's shiny. I will use it on a bunch of nuts, bolts, brackets.
If it hasn't been discussed yet, one way to neutralize the acid is to rinse the parts in a mix of baking soda and water.
-Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Rust removal recipe ! works great! cheap to make!! [Re: 67SATisfaction] #539603
01/10/11 08:59 PM
01/10/11 08:59 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
couple of questions, jamesdart said his batch lost its strength after three days,anybody else had this problem? would putting in a sealed container help? i know my 22 dollar a gallon of evapo-rust did, reused three times.good for bolts, anything larger would cost a fortune. would heating up the mixture help(floating tank heater)we use one for the horse tank. as far as the cost, use the good stuff for delicate parts, the vinegar for the other, a no-brainer.
Re: Rust removal recipe ! works great! cheap to make!! [Re: edl] #539604
01/10/11 11:00 PM
01/10/11 11:00 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
The valance cleaned up nicely, but had too much bondo, so I tossed it. As you can imagine, the longer this stuff sits around, the weaker it gets. I have a 5 gallon bucket of it that has been sitting for several months now. I put a few tools in it recently, for 2 weeks, they came out fine. If you're in a hurry, then it plan on it working for just a few times.
Re: Rust removal recipe ! works great! cheap to make!! [Re: cudaman1969] #539605
01/11/11 02:29 PM
01/11/11 02:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I used the mix and it finally lost much of it's strength after a month or so of it sitting open in my garage .
Re: Rust removal recipe ! works great! cheap to make!! [Re: matthewnokc] #539606
04/06/12 11:49 PM
04/06/12 11:49 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Neato!
