Page 4 of 7 1 2 3 4 5 6 7
Re: Rust removal recipe ! works great! cheap to make!! [Re: roy2345] #539547
12/25/09 10:36 AM
12/25/09 10:36 AM
Port Saint Lucie, FL
ChallengerGary Offline
Great little Home Brew - thanks for posting this
Re: Rust removal recipe ! works great! cheap to make!! [Re: larry890] #539548
12/25/09 11:31 AM
12/25/09 11:31 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
main ingredient was borax washing soda wasnt it?
Re: Rust removal recipe ! works great! cheap to make!! [Re: chrisf] #539549
12/25/09 01:28 PM
12/25/09 01:28 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
By now I've mixed up a few gallons of this stuff. I sat these headers in it for a few days and they cleaned up rather nicely. I wasn't able to keep all of the headers in the solution all of the time but it worked well. A little final clean up and paint and these will be back to new.
I've also been working on a turbo housing. Those things are very rusty and the one I'm working on is about 25 years old. It is taking a little bit of work but I like it better than trying to sand blast it and then hope the sand gets all cleaned out and you don't toast a bearing.
Re: Rust removal recipe ! works great! cheap to make!! [Re: Chilort] #539550
12/27/09 07:08 PM
12/27/09 07:08 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: Rust removal recipe ! works great! cheap to make!! [Re: moparniac] #539551
12/29/09 01:33 PM
12/29/09 01:33 PM
oklahoma city
matthewnokc Offline OP
oklahoma city
http://www.massmopar.com/yabb/YaBB.pl?num=1135525788
I have tried molasses to de-rust parts also.. and it works! But it really makes a sticky stinky mess.. Plus I really had a hard time finding it in my area. But I do think that would be that absolute cheapest way to make some solution and get a decent result..
Re: Rust removal recipe ! works great! cheap to make!! [Re: matthewnokc] #539552
12/29/09 01:46 PM
12/29/09 01:46 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The molasses dip does work, and quite well. It does take plenty of time to do the job, and it does stink, but there's probably not a safer cheap way to de-rust big parts like engine blocks, heads, etc.
I had a big plastic horse trough filled with it, got the molasses for free (stole it from my mom, she has horses ), it works better when warm so I wrapped it with pig blankets (like a heavy duty water proof electric blanket also available at the farm supply store) and kept it warm that way in colder months (worked VERY well and not a huge draw on the power bill) but to do big nasty stuff that needs to soak for a month it's best to hold off til the summer heat arrives. Be sure to keep it covered tightly to retain heat and stave off evaporation.
Re: Rust removal recipe ! works great! cheap to make!! [Re: matthewnokc] #539553
01/02/10 05:19 PM
01/02/10 05:19 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
can you post pic of the lemon juice bottle? are you talking about concentrate? or id like to mix up enuff for a 5 gallon bucket to have around
what about parts that cant be submerged? wonder if you could use like a gravity filter off a aquarium and a tray under the part so it runs over the part collects at the bottom then pumped back to the top
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Rust removal recipe ! works great! cheap to make!! [Re: toplescuda] #539554
01/02/10 05:52 PM
01/02/10 05:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Seriously? Youv'e never seen these in the store? Some are shaped like a lemon, some aren't, all the same stuff.
Re: Rust removal recipe ! works great! cheap to make!! [Re: toplescuda] #539555
01/02/10 06:47 PM
01/02/10 06:47 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I use these....seem to grow on trees around here
Re: Rust removal recipe ! works great! cheap to make!! [Re: ScottSmith_Harms] #539556
01/02/10 07:02 PM
01/02/10 07:02 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
lolol i can honestly say iv never seen them before
1971 charger
Re: Rust removal recipe ! works great! cheap to make!! [Re: toplescuda] #539557
01/02/10 07:11 PM
01/02/10 07:11 PM
Cookeville
Chilort Offline
Chilort  Offline
Cookeville
Re: Rust removal recipe ! works great! cheap to make!! [Re: Chilort] #539558
01/04/10 09:51 PM
01/04/10 09:51 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I got a chance to try it out this weekend and it worked great, although I let it soak for 48 hours just to be sure. It didn’t damage the paint or the seam sealer. I still need to treat the inside with metal prep to protect the bare metal.
If you get a chance you should try it.
Before...
After....
My Monster are real!
Living within your means makes life pretty easy.
Re: Rust removal recipe ! works great! cheap to make!! [Re: 67vertman] #539559
01/04/10 10:01 PM
01/04/10 10:01 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
If you are using it (or any other kind of acid) to remove rust in an enclosed area like that deck lid be DARN sure you neutralize it! That acid will stay active and will allow rust to return with a vengance if left active, and a plain old water rinse won't do the trick no matter how much you flush it.
Re: Rust removal recipe ! works great! cheap to make!! [Re: ScottSmith_Harms] #539560
01/04/10 11:53 PM
01/04/10 11:53 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
That's correct Scott.
I used a Baking Soda rinse, and I am planning on treating the whole inside with Pixle 20 Rust and metal prep.
Re: Rust removal recipe ! works great! cheap to make!! [Re: 67vertman] #539561
01/09/10 10:52 PM
01/09/10 10:52 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Well I had to give it a try and OMG did it work well. 24 hours later and this is what I had.
But do yourself a BIG favor. Don't use an aluminum pan to soak your parts in. In 36 hours you will have a pan with many holes in it and a big mess......don't ask me how I know.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Rust removal recipe ! works great! cheap to make!! [Re: Troy] #539562
01/09/10 10:52 PM
01/09/10 10:52 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Re: Rust removal recipe ! works great! cheap to make!! [Re: Troy] #539563
01/09/10 10:57 PM
01/09/10 10:57 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
...does not do very much to painted parts however. But this could be a good thing. Somebody needs to soak a part that has many inspection marks on it to see how that comes out. In theory it should remove the rust and keep the inspection marks behind. Anybody have a 8 3/4 third member that they could try this on???
Re: Rust removal recipe ! works great! cheap to make!! [Re: Troy] #539564
01/09/10 11:12 PM
01/09/10 11:12 PM
The paint will come off it just takes a little longer.
I did a license plate bracket from a '63 330 and it's taken about 3 weeks but the black paint is almost all gone. Seems to come off in sheets/bubble off.
Paint usually stays intact on parts that you don't dip for very long.
I've put lots of parts in my "brew" in the past few weeks and they all come out looking like new!
Re: Rust removal recipe ! works great! cheap to make!! #539565
01/09/10 11:41 PM
01/09/10 11:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Troy,
You are seeing the results of what acid does to nearly any metal, that's why they sell it in plastic jugs
It's also why I caution users against using the home brew on delicate or plated items as it will remove the rust first, but the good metal is next, it's just slower acting on good metal. The products I've mentioned before such as Evaporust will give the same rust removing results (yes it costs more than vinigar & lemon juice) without doing ANY harm to the good metal below it, so choose your rust removal products wisely.
*Ever cover your leftover spaghetti with aluminum foil? If the foil is toucing the foil you'l find holes in it the next day!
Re: Rust removal recipe ! works great! cheap to make!! [Re: ScottSmith_Harms] #539566
01/10/10 12:05 AM
01/10/10 12:05 AM
Woodbridge
Tommy The Chryco Offline
Woodbridge
so How do you neutralize it? anyone?? thanks in advance
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
