'68 BBody Drum 2 Disc plumbing help needed.. #539374
11/28/09 08:12 PM
11/28/09 08:12 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
How should I plumb my brake swap. I am putting in Manual Discs up front to replace the power drums.
I have a set of spindles from a "A" body ('75)
and the 11.75 calipar adapters.
My question is should I re-use my drum brake dist. block and plumb a adjustable proportioning valve behind it to the rear brakes or...
Use a proportioning valve from the donor car?
Chuck
Re: '68 BBody Drum 2 Disc plumbing help needed.. [Re: moparrulzzz] #539375
11/28/09 08:46 PM
11/28/09 08:46 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
either will work.
Re: '68 BBody Drum 2 Disc plumbing help needed.. [Re: moparrulzzz] #539376
11/28/09 11:42 PM
11/28/09 11:42 PM
that'd be my choice & see how it performs and possibly also adding the adjustable one in the rear line either at the same time or later if needed
Re: '68 BBody Drum 2 Disc plumbing help needed.. [Re: RapidRobert] #539377
11/29/09 08:42 PM
11/29/09 08:42 PM
Mansfield,Ohio
Mansfield,Ohio
Were all the proportioning valves the same on all cars? I mean would a '75 Dart and a '75 C-Body(pick the model) have the same proportioning vavle in it? Just curious as I am doing a '68 B Body and the donor I have is a '75 A body. I am sure there is a bit of a weight difference there if it matters.
Chuck
Re: '68 BBody Drum 2 Disc plumbing help needed.. [Re: moparrulzzz] #539378
11/29/09 09:07 PM
11/29/09 09:07 PM
Chuck different ones have different proportioning though I"m not sure how much difference there is beween them & I'm not qualified to suggest the one that would be the best for your app as I am strickly into A bodies. You might contact Doctor Diff if no one else chimes in
