550hp cruiser build- what motor/tranny would you do? #538318
11/27/09 07:37 PM
11/27/09 07:37 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Well im thinking about pulling my #'s matching drivetrain and building a big block with an auto behind it. Im looking for input on what specs you would go with to obtain 550hp/600ft lbs (or thereabouts) to cruise-how would you build it specifically?
I figure id get a built 727 as well. Who can build a turnkey 727 to handle that mild power?
Just looking for input now to get it on paper and maybe tinker with it. Im tired of tinkering with the original drivetrain and piece-mealing stuff.
Re: 550hp cruiser build- what motor/tranny would you do? [Re: AHall] #538319
11/27/09 07:50 PM
11/27/09 07:50 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
what rear end also?
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: 550hp cruiser build- what motor/tranny would you do? [Re: jrlegacy23] #538320
11/27/09 07:51 PM
11/27/09 07:51 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
what rear end also?
good point, id probably rebuild the stock one under there- what do you think? It is original- currently has 3.55's in it.
Re: 550hp cruiser build- what motor/tranny would you do? [Re: AHall] #538321
11/27/09 08:01 PM
11/27/09 08:01 PM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
I'm running just what you describe in the Satellite. It's a 440 stroker with the 440 Source 4.15" kit, displacing just under 500 CI. Eddy heads, old style Torker manifold (I had it), Holley 850 DP, Comp XS274S cam 236/242 @.050", .502"/.511" lift. Exhaust is 2" TTI's. The motor made 505 HP and 603TQ on the dyno.
The transmission is a CRT "Pro Street" 727 with reverse manual VB. I highly recommend giving John Cope at CRT a call. You wont find a better person to deal with and this trans works great!
Re: 550hp cruiser build- what motor/tranny would you do? [Re: hydro] #538322
11/27/09 08:11 PM
11/27/09 08:11 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
hey thanks man!
how streetable is the build? how hot does it get in traffic? Anything different you would change if you had to do it again? Who built your motor? Did CRT?
Re: 550hp cruiser build- what motor/tranny would you do? [Re: AHall] #538323
11/27/09 09:14 PM
11/27/09 09:14 PM
SoCal
Brian Hafliger Offline
SoCal
I did a 505 BB using a Source 4.25 crank and a 440+.030 for a customer about a year ago using Stealth heads (I prefer Edelbrock)and a hyd. roller cam. It made 615TQ and 535HP and idled around 750-800rpm!
Here's a link:
https://board.moparts.org/ubbthreads/show...amp;Search=true
Brian Hafliger
Re: 550hp cruiser build- what motor/tranny would you do? [Re: AHall] #538324
11/27/09 09:39 PM
11/27/09 09:39 PM
AndyF Online content
AndyF  Online Content
I wrote a whole book on that subject!
I have a motor like that getting ready to go to the dyno right now. 440 with 4.250 crank, ported Edelbrock heads, hyd roller camshaft, dual quad intake with twin 500 cfm carbs. This motor will be for sale once we finish dialing it in on the dyno.
Re: 550hp cruiser build- what motor/tranny would you do [Re: AHall] #538325
11/27/09 10:25 PM
11/27/09 10:25 PM
hartsburg mo
biggerredz71 Offline
hartsburg mo
Im running a 505 4.250 source crank,7.1 rods,stealth heads,Hughes hyd flat tappet 250-255 dur@.50 576-593 lift,727 with 4200 stall,3.55 gears.This car is a blast to drive.Im not sure of HP#'s.Im thinking around 550-600hp Block has been zero decked and i took .40 off the heads.
Re: 550hp cruiser build- what motor/tranny would you do [Re: AndyF] #538326
11/27/09 10:29 PM
11/27/09 10:29 PM
hartsburg mo
hartsburg mo
Andy i just bought your book last weekend!!GREAT BOOK.. Wish i had it when i was building the new 505 but i think it turned out all right.The one thing im not sure about is the hyd cam but oh well.
Re: 550hp cruiser build- what motor/tranny would you do [Re: biggerredz71] #538327
11/27/09 10:53 PM
11/27/09 10:53 PM
IN
ahy Offline
ahy  Offline
IN
How about overdrive? Behind a big high torque 500 it would quiet things down, extend the life of your engine and save some fuel, especially if you will be getting out on the highway.
A Gear Vendors behind a 727 or the Keisler OD automatic would fit the bill.
Re: 550hp cruiser build- what motor/tranny would you do [Re: ahy] #538328
11/27/09 11:01 PM
11/27/09 11:01 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
yea, OD is a must.
would you go GV or Keisler?
Re: 550hp cruiser build- what motor/tranny would you do [Re: AHall] #538329
11/27/09 11:13 PM
11/27/09 11:13 PM
IN
ahy Offline
ahy  Offline
IN
Both are great options. The gear vendors is well proven and the Keisler is shorter and lighter. In terms of cost, by the time you buy a well built 727 plus the GV unit I'm not sure there is much difference.
I went with a 5 speed Keisler manual behind a 550 ish HP 496 low deck. I love it.
Re: 550hp cruiser build- what motor/tranny would you do [Re: ahy] #538330
11/27/09 11:50 PM
11/27/09 11:50 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
How fast are you looking to go and what car is this going in ?? Ron
Re: 550hp cruiser build- what motor/tranny would you do? [Re: hydro] #538331
11/27/09 11:51 PM
11/27/09 11:51 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You need a much more agressive cam. I bet you can pull alot more hp with a bigger cam. Very nice car. Ron
Re: 550hp cruiser build- what motor/tranny would you do [Re: 383man] #538332
11/28/09 12:47 AM
11/28/09 12:47 AM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
high 11's would be plenty.
73 Charger.
Re: 550hp cruiser build- what motor/tranny would you do [Re: AHall] #538333
11/28/09 01:15 AM
11/28/09 01:15 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I like the bigger is better approach. We built a 523 (4.350x4.375) 440 with regular port victors and a victor intake. Hydraulic roller cam in the 250 @ .050 range. 10.5:1 and it made 640 hp and 650 tq. Going into a challenger. I expect it'll make a great street motor. Power's all done by 6200 rpm.
Re: 550hp cruiser build- what motor/tranny would you do [Re: dodgeboy11] #538334
11/28/09 01:37 AM
11/28/09 01:37 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Stock stroke 440, edelbrock rpm or 440source stealth heads, lunati voodoo 60304 or comp xe285hl, eddy rpm intake, holley 850dp, 4.10 rear gear and a 3000rpm or higher stall converter will get you into the 11's with ease and put out around 550hp. If you go with the CNC ported version of the heads and step up a little in cam you should be able to do near 600hp.
Re: 550hp cruiser build- what motor/tranny would you do [Re: dodgeboy11] #538335
11/28/09 03:04 PM
11/28/09 03:04 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I think if you run a big engine you can get away with a stock transmission. The idea of the stroke is to make a torque monster streeter that can pull hard with say 3.23 or 2.94 gears. It works for me with my 471 incher and 3.23 gears anyway. I've thought of changing to 2 series gears but the car cruises great at 80-90 MPH with the 3.23's and I need my driver's license.
Sheldon
Re: 550hp cruiser build- what motor/tranny would you do [Re: RUNCHARGER] #538336
11/28/09 06:43 PM
11/28/09 06:43 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
I think my original 727 needs rebuild soon. I just went to the gas station and I took off pretty hard and it went, "shift, shift" into 3rd within seconds. Plus i dont get that "seat of the pants" shift.
Re: 550hp cruiser build- what motor/tranny would you do [Re: RUNCHARGER] #538337
11/28/09 06:44 PM
11/28/09 06:44 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Sheldon
Im currently running 3.55's.
