Page 2 of 3 1 2 3
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: deaks] #537793
11/27/09 09:06 AM
11/27/09 09:06 AM
Orlando Florida
blown572dart Offline
Orlando Florida
RIP
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: blown572dart] #537794
11/27/09 09:27 AM
11/27/09 09:27 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
RIP
Sorry for your loss
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: B1KILLER] #537795
11/27/09 10:39 AM
11/27/09 10:39 AM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
A similar thing happened to me back in the 70's. First gear galled on the shaft as I shifted into 4th gear at over 100 mph. The tranny and drive shaft looked like yours. It even took all the teeth off the ring and pinion gear. I suggest you check your rear end. It got may attention real quick as my hand was still on the shifter as it almost disappeared down below the floorboard.
I hope it doesn't cost an arm and a leg to get the car back on the strip. You REALLY NEED an SFI bellhousing.
Raul
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: DemonDust] #537796
11/27/09 10:43 AM
11/27/09 10:43 AM
, PA
sleepyhead416 Offline
, PA
Race or Street Why no scattersheid ? Sorry for ur loss but legs are important.
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: Aspen7695] #537797
11/27/09 11:16 AM
11/27/09 11:16 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
Raul
reminds me of my z28 back in high school...i stuck it in reverse at speed...with 2 (football sized players)friends in back seat.
it the shifter handle stayed in my hand the rest of the trans..proceeded to shread my trans tunnel..like a horror movie..
it fell out of the car and i ran over it..
i still had the shifter in my hand..lol...
broke the block just like yours did..
your lucky the car didnt wreck...
it bruised our star football players foot...he couldnt walk/play for 2 weeks...fwiw
condolences..
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: DemonDust] #537798
11/27/09 11:17 AM
11/27/09 11:17 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Looks like driveshaft to me.
failed and took out rest of components in order.
snapped tail, then case, bell and block.
good example as to why they put supports on lower half of bellhousing to block.
once that shaft goes its done, a place not to skimp.
1350 joints, forged yokes and moly tube, even that is not fore sure.
I'd be more sick from thinking about that factory bell failing.
Sorry for your loss.
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: sleepyhead416] #537799
11/27/09 11:24 AM
11/27/09 11:24 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
The reason I didn't have a lakewood on here was because it's maybe a 450 hp car. I know alot more people with higher hp SB still running stock bells.
I wonder if it was a cast iron case if it would have made a difference???
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: 6T6Cuda] #537800
11/27/09 11:31 AM
11/27/09 11:31 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I'd have to assume that something locked up in the trans ro spin it on the bellhousing and break the ears like that. I'll be interested to see what the inside looks like. Bummer!
It looks like the trans got jammed up by going into both 2 and 3 gears (there is a lockout on the housing that is "suposeto" prevent this). With the extra power it just did not break loose, A broken fork (between the 1-2) may have cause it not to get out of gear.
Once the trans locked up hard, the weight of the car and the momentum, just twisted the entire engine / tras until something had to give; unfortunately the parts were so equal, a lot gave...
Look at the direction of the twist on the drive shaft, I bet it is not clockwise (going forward) it is ccw (because the wheels were driving against a stopped load)
Be careful taking the tras apart and do some good careful looking to get to the root cause, but that is crazy...
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: DemonDust] #537801
11/27/09 11:33 AM
11/27/09 11:33 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
have seen the cast tails fail also, tho not the case but i havent seen it all by far.
1st time I saw a block lose an ear tho, agree it is repairable.
how does the crank and rear main area look?
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: theclutcher] #537802
11/27/09 11:36 AM
11/27/09 11:36 AM
Roanoke Va
gearjammerdart Offline
Roanoke Va
I had a clutch come apart and locked up the rear causing the driveshaft to fail. It also broke one ear on the tranny and bottom ear on the block. In this case I was in the top of 4th and pushed the clutch in to take it out of gear. (won't do that again lol)
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: gearjammerdart] #537803
11/27/09 11:48 AM
11/27/09 11:48 AM
Menomonee Falls
Menomonee Falls
The back of the crank has no damage. The clutch isn't broke either.Flywheel bolts are all in tact.
Some one asked about the floor, there is only a small dent right where the sheetmetal on the floor goes up over the rear.
Here's a pic you can kinda see....
SDG Motorsports
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: DemonDust] #537804
11/27/09 11:52 AM
11/27/09 11:52 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
was that 18 spline internals?
wondering just what failed, keep us up to date.
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: theclutcher] #537805
11/27/09 12:18 PM
11/27/09 12:18 PM
Menomonee Falls
Menomonee Falls
No just 23 spline, it was only a mild build
I'll probably take the trans apart next week, see whats in there
The rear looks good too except for it snapped 3 of the 4 heads right off the bolts that hold the u joint straps on....
SDG Motorsports
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: theclutcher] #537806
11/27/09 12:31 PM
11/27/09 12:31 PM
Az
Crizila Offline
Crizila  Offline
Az
I see todays racers are making the same mistake as those 40+ years ago did - no scatter shield. I was only stupid ( and darn lucky )once. Considerable more violent explosion than what you went through and still had all my digets ( but not much else )at the end of the track. BTW, had similar block damage and was able to have it repaired.
Fastest 300
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: DemonDust] #537807
11/27/09 01:22 PM
11/27/09 01:22 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I am going to say no...I had a similar incident in my valiant when I broke a shift fork and went for 3rd gear and then all hell broke loose. My bell broke right where yours did near the opening for the clutch fork. It snapped the ears off of the trans case (cast iron) just like yours did. Talk about !
Did that trans have steel shift forks?
ps...so what does the shifter handle look like?
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: Jeremiah] #537808
11/27/09 04:12 PM
11/27/09 04:12 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Looking at the driveshaft I have to agree that the transmission locked up. The twist on the shaft is the wrong way. Sorry to see that. Quicktime makes some nice bellhousings for what it's worth. Completely off topic, but I notice your oil filter plate only has four holes. I feel it's worth it on any small block to drill four more in there.
Hope you can get it back on the road soon.
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: dodgeboy11] #537809
11/27/09 04:29 PM
11/27/09 04:29 PM
Az
Crizila Offline
Crizila  Offline
Az
Lets see now - A stickshift car with a factory stock driveshaft, factory stock bellhousing, assume you had a driveshaft loop ( in the right spot)at least, 200HP shot to a 400 ( at minimum ) HP 340? Sorry for your breakage, but you had it commin. Consider yourself lucky and take a wise-up pill!
Fastest 300
Re: Duster Carnage Pics..... Makes me sick....340 4 sp [Re: Crizila] #537810
11/27/09 04:42 PM
11/27/09 04:42 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have seen this exact thing before but the iron case and tail held up a little better.It also knocked the advance plate loose inside the distributor.Something else you might want to check along with the hub on the disc.If you need a small bearing case send me a PM The shipping will be higher than the price of the case
Gus
64 Plymouth Savoy
Dana 60
Re: Duster Carnage Pics..... Makes me sick....340 4 sp [Re: fourgearsavoy] #537811
11/27/09 05:19 PM
11/27/09 05:19 PM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
I saw this on YB. I feel for you. It makes me sick looking at these pics too
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: Duster Carnage Pics..... Makes me sick....340 4 speed [Re: ScottSmith_Harms] #537812
11/27/09 06:10 PM
11/27/09 06:10 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
Was that a numbers matching drive train that just got grenaded?
your joking right? .... anyways, that sucks man. glad you are ok. stuff like that can get ugly. good to see its not any worse. sorry for your loss.
Page 2 of 3 1 2 3
