Re: Vibration when I let off throttle at the end of a run
[Re: galen]
#536661
11/25/09 07:12 PM
11/25/09 07:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Why would the rear be moving forward.... shouldnt... if it is a pinion angle issue it would most likely get worse on the decell if you put more pinion angle to it... JMO
[Re: galen]
#536662
11/25/09 07:28 PM
11/25/09 07:28 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Ring/pinion setup issue..? Sounds like too much backlash maybe coasting.
If you like drag racing, support your local track.
