I have a 1969 (440 HP) block that I'm building into a 500 stroker. I already have the kit and have clearanced the block and drilled the oil galleries, etc... and ready to assemble the short block.
When looking for the right CAM I found the Voodoo 60332 SOLID ROLLER CAM with the following specs:
Advertised Duration (Int/Exh): 273/279
Duration @ .050 (Int/Exh): 243/249
Gross Valve Lift (Int/Exh): .578/.585
LSA/ICL: 110/106
Valve Lash (Int/Exh): 016/016
RPM Range: 2800-6800
But I want to use Hydraulic Roller Lifters... (NOT SOLID) and I cant find anyone that actually sells these and has them in stock.
Another option is to go with a Lunati Voodoo HYDRAULIC FLAT TAPPET Part# 60305 with the following specs:
Advertised Duration (Int/Exh): 284/292
Duration @ .050 (Int/Exh): 242/252
Gross Valve Lift (Int/Exh): .533/.552
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2500-6600
At least with this cam I can buy the hydraulic lifters and go down the road without adjusting every few weeks.
QUESTION:
Since a stroker motor eats up a lot of CAM, will my Hyd cam above Part# 60305 be a little weak ?
Does anyone know where I can find hyd roller lifters so I can go with a Roller Cam ?
Any other cam suggestions for a 500 ci stroker that will be installed into a (4-Speed) 70 6-Pack Challenger used for street as well as 1/8 and 1/4 Weekend races ?
Note: This is a manual shift 4-Speed car.
500 ci stroker
11.1 compression
OEM Mopar Six Pack carbs
Headers
I want power and a good strong thump thump and I know that with a longer stroke...most cams designed for a 440 will not be as effective as they would with a factory stroke.
THanks
Mike
