Donor for E body horns #536410
11/25/09 03:11 PM
11/25/09 03:11 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
What is a good donor vehicle(s) for 72 Cuda horns?
Re: Donor for E body horns [Re: JonC] #536411
11/25/09 06:17 PM
11/25/09 06:17 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Do you have anything of the old horns ??? {like the mounting brackets ?}...The high and low note prestolite horns themselves are pretty much standard pieces other than the date code...They were made through a broad range of years...Any mopar from the mid 60s to the mid 70s should have the same high/low horns...The attaching brackets vary depending on the model...The barracuda bracket is basically an "L" shaped piece...Here's a pic of some E-body horns someone posted in another thread....
Re: Donor for E body horns [Re: screamindriver] #536412
11/25/09 08:16 PM
11/25/09 08:16 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I have one horn but don't know if it is high or low. Was wondering if any car from that era is the same.
Re: Donor for E body horns [Re: JonC] #536413
11/25/09 08:19 PM
11/25/09 08:19 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Inspect your horn closely--chances are good you will find either "HI" or "LO" embossed on it.
Re: Donor for E body horns [Re: Pacnorthcuda] #536414
11/27/09 10:05 AM
11/27/09 10:05 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
So what is the best way to clean them up? Can you bead blast? Can you just stuff some rags in the opening and tape if off before you blast or is there a better way of doing it?
Re: Donor for E body horns [Re: burdar] #536415
11/27/09 01:17 PM
11/27/09 01:17 PM
Harrisburg, Pa.
Harrisburg, Pa.
All I've ever done is stuff a rag up in there and blast...The RR horns with the open diaphram are a little tricky to do....
