Rods checked out, now a question
#536207
11/25/09 02:34 AM
11/25/09 02:34 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Had a set of .990 pin aftermarket rods with time on them checked out. Three of the 4 in one bank came back with wear on the pin bushings (need the bushings replaced.) Just coincidence or common on BBM, don't oil as well on one side? The other 5 are well within spec. Should I have them all done as a set or just the ones that need work. ![](/ubbthreads/images/graemlins/confused.gif) Everything is going for balance before assembly.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Rods checked out, now a question
[Re: Cab_Burge]
#536209
11/25/09 03:03 AM
11/25/09 03:03 AM
R70RUNNER
Riverside, Ca
Cab, They are not going back into the same engine again, totally different build. was 400/451----> to 440/446... I had them check as routine the 3 in question are now .992 the other five are 9.89 +/- .0002 I'm ok with running the 5 as-is as long as I'm not advised not to ![](/ubbthreads/images/graemlins/thumbs.gif) Thanks
