Where do OEM 440 forged cranks typically crack? #535364
11/24/09 12:09 PM
11/24/09 12:09 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
From what you've seen when OEM 440 forged cranks develop cracks, do they tend to show up in the same general area, e.g. are they more likely to occur in the main journals than the rod journals?
Also, do the upgrades (band-aids?) that can been done w/ an OEM block, for example using a girdle, cross-bolted main caps or aluminum caps, seem to have any influence on where the crank cracks develop?
Thanks!
Re: Where do OEM 440 forged cranks typically crack? [Re: BradH] #535365
11/24/09 02:54 PM
11/24/09 02:54 PM
AndyF Online content
AndyF  Online Content
From what I've seen they all crack in the mains at the rolled fillet. The rolled fillet design is great for OEM engines but not so hot for 500+ hp, especially sustained duty. I think the factory engineers recognized that problem back in the day and went with a different design for the NASCAR stuff. Those old NASCAR motors from the 70's made about as much power as a lot of street guys these days!
Re: Where do OEM 440 forged cranks typically crack? [Re: AndyF] #535366
11/24/09 03:10 PM
11/24/09 03:10 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
The only crank I ever broke was a Crankshaft Specialist forged crank that broke on the number 5&6 rod throw. Totally broke off of the crank and into the side of the block.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Where do OEM 440 forged cranks typically crack? [Re: BradH] #535367
11/24/09 05:42 PM
11/24/09 05:42 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I usually see them cracked at the undercut fillet. As for what precautions? Just the usual stuff. Avoid detonation, Good balance job, quality damper, proper main saddle bore alignment.
MB
Re: Where do OEM 440 forged cranks typically crack? [Re: BradH] #535368
11/24/09 11:29 PM
11/24/09 11:29 PM
an8sec70cuda Offline
The #4 main is where I've seen a lot of them crack. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
