Converter slipage calculator #535335
11/24/09 12:03 PM
11/24/09 12:03 PM
Gilbert, AZ
Aspen7695 Offline OP
Gilbert, AZ
Can anyone tell me where I can find one. I want to check mine now that I have changed the rear end gears.
Thanks,
Raul
Re: Converter slipage calculator [Re: Aspen7695] #535336
11/24/09 12:07 PM
11/24/09 12:07 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Re: Converter slipage calculator [Re: Aspen7695] #535337
11/24/09 01:00 PM
11/24/09 01:00 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
tci website has one
Re: Converter slipage calculator [Re: abodiesonly1] #535338
11/24/09 01:06 PM
11/24/09 01:06 PM
Gilbert, AZ
Gilbert, AZ
Thank you very much for the link. I came out with 4.685% with the 4.56 gears and 4.764% with the 4.86 gears. I guess I'm in pretty good shape.
Raul
Re: Converter slipage calculator [Re: Aspen7695] #535339
11/24/09 02:40 PM
11/24/09 02:40 PM
Raul
don't forget about instrument errors on electric tachs 3 to 5 % is considered good on a race conveter, I know guys that will do anything to get one better than 3% My 10 inch calculates to 12% by using RPM and tire circumference the old way, I really wish that I had a data aquistion system on the car that would accuretly measure drive shaft and engine RPMs, that would tell me the real slippage in every gear and on the gear change
Re: Converter slipage calculator [Re: Cab_Burge] #535340
11/24/09 08:12 PM
11/24/09 08:12 PM
ky
68roadrunner Offline
ky
Raul
that is nothing that money will cure.
Re: Converter slipage calculator [Re: Aspen7695] #535341
11/25/09 05:49 PM
11/25/09 05:49 PM
New York
polyspheric Offline
polyspheric  Offline
New York
But...
you don't need any more than a pencil and a cocktail napkin if it's just a comparo between actual RPM (observed data) and predicted RPM (from tire OD + gear).
What's missing is tire expansion - which varies with MPH and all tire variables (pressure, rim width, # of plies in carcass), but not completely linear (how fast does it have to turn before it's reached maximum OD?) and always tends to reduce the apparent slip because it lowers RPM.
If you have a Goodyear rep, ask him if expansion data is available for your series.
Boffin Emeritus
Re: Converter slipage calculator [Re: 68roadrunner] #535342
11/25/09 10:57 PM
11/25/09 10:57 PM
Raul
Money isn't the problem when it comes to instrument error The problem is when do you know for sure that your instruments are measuring accurately I have seen many instrument errors in after market high performance guages over the years that I have been racing
