Temp switch taking up a lot of room #535109
11/24/09 12:57 AM
11/24/09 12:57 AM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
Do I need to find a new spot to mount my switch?
It is installed drivers side port next to stat.
Re: Temp switch taking up a lot of room [Re: skep419] #535110
11/24/09 01:02 AM
11/24/09 01:02 AM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
Pic from blackberry inside T-stat
Re: Temp switch taking up a lot of room [Re: skep419] #535111
11/24/09 01:15 AM
11/24/09 01:15 AM
is it bottoming out in there & not screwing in all the way?
Re: Temp switch taking up a lot of room [Re: RapidRobert] #535112
11/24/09 01:20 AM
11/24/09 01:20 AM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
Not bottoming out. It's in all the way. just worried about the flow
Re: Temp switch taking up a lot of room [Re: skep419] #535113
11/24/09 01:36 AM
11/24/09 01:36 AM
I wondering if a fitting like the extras that come w temp sender units between the sender and the manifold to raise it (the sender) up but still leave have enough penetration into the coolant would work. SB intake?
Re: Temp switch taking up a lot of room [Re: RapidRobert] #535114
11/24/09 01:37 AM
11/24/09 01:37 AM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
yep sb intake
