Re: AAR slip yoke question
[Re: AAR70]
#534733
11/23/09 06:56 PM
11/23/09 06:56 PM
Posts: 26,011 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The parts book doesn't make any distinction for the AAR, it uses the same 7290 as a 340-4.
[Re: Alaskan_TA]
#534736
11/23/09 11:40 PM
11/23/09 11:40 PM
Posts: 6,437 Abilene, Texas
fastmark
Abilene, Texas
I do not have the numbers memorized, but AAR & T/A driveshafts use the small u-joint in the front & the large one in the rear.
This has come up before, but my AAR has the same size joint front and rear.
[Re: Snoopy]
#534739
11/24/09 02:03 AM
11/24/09 02:03 AM
Posts: 29,660 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Yep, correct on both. My 70-71 parts book shows both numbers, but the only u-joint referrenced for them is the 7260. This is odd. My 1970 318 barracuda had the big & little driveshaft also, but there is not a referrence in the parts book that spells out two different u-joints that I can find? Mistake in the book? Is it shown in a different revision? Or am I just missing a connection somewhere? I have seen the big & little combinaion in every A53 E-body I have checked. ![](/ubbthreads/images/graemlins/shruggy.gif)
