Uh oh, white smoke in the exhaust #534657
11/23/09 05:02 PM
11/23/09 05:02 PM
I can see Pikes Peak
moparcollector Offline OP
super gas
super gas
I started up my 73 RR clone yesterday - it hasn't been used all year. Brought it over to my compressor to put some air in the tires and thats when I noticed I had white smoke (yes, antifreeze smelling smoke) coming out of the passenger side of the duals.
I ran it a while so it would get warm and drove it about a half mile on my dead end street. Still smoking after that.
So, about 8 years ago I had a head gasket go and it had causes a HUGE amount of white smoke out the tailpipe, but this wasn't nearly as much.
Other than a blown head gasket or cracked head, what else might I be looking at?
It's a 440, '78 vintage, with mostly stock parts except cam, headers, intake, carb.
I could do a compression test - that would show the offending cylinder right?
Greg
Re: Uh oh, white smoke in the exhaust [Re: moparcollector] #534658
11/23/09 05:04 PM
11/23/09 05:04 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
check your plugs. the nice and clean one is the problem chamber
Re: Uh oh, white smoke in the exhaust [Re: moparcollector] #534659
11/23/09 05:30 PM
11/23/09 05:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I would suspect a header bolt weeping into the tube thru the gasket, might want to drain your oil, check for water/antifreeze also, lucky your cylinder didn't fill!,....antifreeze in a header pipe takes a long time to "exhaust".......usually the 3/5 or 4/6 numbered cylinders are the culprits for leaking from the bolts
Mike
Re: Uh oh, white smoke in the exhaust [Re: DAYCLONA] #534660
11/23/09 06:26 PM
11/23/09 06:26 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I read on the Jag site that brake fluid, coming through the brake booster vacuum line, will smoke white also... If you have PB.....
Re: Uh oh, white smoke in the exhaust [Re: minivan] #534661
11/23/09 06:49 PM
11/23/09 06:49 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
first off I would make sure that it isn't condesation. It is that time of the year and there are many times I have seen one side a lot worse than the other. If your coolant isn't way low I would do some more checking before jumping to conclusions. Your coolant level may even look low after standing for a period of time when in reality it is not or just meeds topping off.
Don't start taking anything apart til you do some in depth checking. Head gaskets are not really that proe to leaking.
Re: Uh oh, white smoke in the exhaust [Re: minivan] #534662
11/23/09 06:50 PM
11/23/09 06:50 PM
super gas
super gas
Ok some things to check out - thanks guys. Will update with findings later.
